Home > In Car Electronics > Good value speakers? |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 |
Got a td5 90 CSW with standard speakers front and rear and an aftermarket pioneer head unit. I'm planning to add an active sub at some point but for now id like to simply upgrade the standard LR speakers. Reading other threads I believe they are 4" front and rear?
The sound quality is pretty poor and tinny and I mostly listen to rock/metal so would ideally like to get some speakers with decent mid and certainly more bass. The rear has standard enclosures and the fronts are mounted as standard on the bolt on aircon unit. The question I have is there are any recommendations that won't break the bank for front and rear where I can keep the standard housings? Not sure if there is much room behind the rear enclosures or behind the speakers in the aircon so not sure if I need speakers that are particularly slim too? Thanks all! |
23rd Mar 2015 8:11pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20512 |
They are 10cm on the Puma but as far as I'm aware they are also on the TD5 too.
Have a look at these: http://www.justkenwood.co.uk/car-audio.aspx/kfc-e1065-speakers They are good value and have a fairly low frequency response down to 45Hz which will improve the bass response and mid range. |
23rd Mar 2015 8:48pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
I went with Steve's recommendation when i did similar
I fitted those in the front and disconnected my tweeters [Too tinny] Also, you can buy the kfc-e 1365 [The 5" version] for the rear, they fit with only minor trimming of the standard speaker housing - dead easy and even better sound sound is MUCH improved, not up to sub standards, but far more bass than before Guns and Landrovers .... anything else is irrelevant. |
23rd Mar 2015 9:11pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
It's all about de bass...
Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
23rd Mar 2015 9:23pm |
Perfect. Thanks for the replies chaps, shall make a purchase me thinks!
23rd Mar 2015 9:28pm |
Manufacturer choice and selection are getting more and more limited now.
23rd Mar 2015 9:29pm |
... No treble Guns and Landrovers .... anything else is irrelevant. |
23rd Mar 2015 9:36pm |
I'm more than happy to go with something that has first person feedback
23rd Mar 2015 9:38pm |
Right, order placed
23rd Mar 2015 9:41pm |
And I always thought it was 'No trouble'... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
23rd Mar 2015 10:02pm |
24th Mar 2015 9:18pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3648 |
have also ordered the Kenwoods via E/BAY with the slightly larger ones for the rears £54 all in hopefully improves things a bit DEFENDER 90 TDCI XS,
26th Mar 2015 6:06pm |
Let us know how you get on.
I paid £80 for a set years ago so they are better value |
26th Mar 2015 6:25pm |
Exactly what i did. Difference is most noticeable, much nicer sound. But i also disconnected the dashtop tweeters .. the tinny'ness of those cancelled out the improvement in bass ... sounds much better without them Guns and Landrovers .... anything else is irrelevant. |
26th Mar 2015 9:14pm |
