Home > Td5 > So I have the engine out and the head off
Page 1 of 3 123>
Welkman
Hi Guys,
After a bit of advice. I have the engine out of my 110 (TD5 2005) and am in the process of doing the head gasket and clutch. I originally stripped the engine out due to a leaking FPR, diesel on the clutch and a mystery coolant loss.
A few questions: the bellhousing was lined with an oil like but diesel smelling substance which I assume is diesel from the FPR mixed with clutch dust but will change the main oil seal on the block to be safe. Does this sound familiar to anyone?
What steps should I take on the head strip down? Currently only the valves are left in place but the inlet valves were ringed with baked on goop which I assume is courtesy of the ERG (now gone). Do you reckon I should have them out and relap them myself or get the machine shop to do it? How do i make sure the fuel supply to the injectors stays clean?
I have the core plug out from the exhaust manifold side as I am trying to eliminate any sources of coolant leakage, what is the correct way to seal this when I put it back?
I am also replacing the waterpump.
Whilst I am there I was wondering if there are any other jobs I should do whilst access is good?
James
Post #409483 21st Mar 2015 10:18am
Anderzander
Would you take lots of pictures please ?
Post #409493 21st Mar 2015 10:45am
Welkman
Also I forgot to ask, if I want to de gunk the top of the cylinders can I remove the timing chain completely to crank over the bottom end, clean and then re time by finding tdc of the no 1 piston and re lining up the chain with the one marked link at the bottom and the two marked links at the top?
Post #409495 21st Mar 2015 10:47am
Welkman
I can take a few of the head stripped down. and the bell housing. Will get on it before the rugby starts and upload later Smile
Post #409497 21st Mar 2015 10:48am
Welkman
Block
Timing chain did not have the two black links described but two with script engraved that lined up.
Head stripped
What the rocker cover looked like
Cam shaft
Injector clamps etc all kept in order
Injectors bagged and labelled
Leaking FPR
Bell Housing gunk
Fly wheel
Sad Landy
Post #409532 21st Mar 2015 1:00pm
Welkman
Inlet manifold nice and clean and no oil in the intercooler. Might put an alisport one on Wink
Thinking of replacing the cooling hoses as they are worn in places.
Post #409537 21st Mar 2015 1:02pm
Welkman
Other side of the water pump
Post #409538 21st Mar 2015 1:03pm
Welkman
I would like to get everything as clean as possible before reassembling, ideas?
Post #409540 21st Mar 2015 1:08pm
ibexman
Dishwasher Whistle
Post #409580 21st Mar 2015 3:15pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
That's all well and good if you can smuggle it into the kitchen without a certain someone noticing.
Then trying to explain why you have a sudden urge to use the dishwasher all night!
How do I know? Whistle 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #409585 21st Mar 2015 3:27pm
Welkman
I am totally cool with using the dishwasher but Im worried about the internal fuel feed, will it contaminate anything?
Post #409594 21st Mar 2015 4:15pm
Welkman
Post #409602 21st Mar 2015 4:30pm
Anderzander
Thanks for the pictures - great to see !
If you are ticking off problem areas whilst it's out - you could check the oil pump bolt, uprate the exhaust manifold studs, new o rings in the fuel cooler, and check the oil cooler for corrosion ?
Post #409802 22nd Mar 2015 8:44am
Anderzander
Love that YouTube ad !! Smile
Though that spanner must have hurt "ouch!"
Post #409803 22nd Mar 2015 8:49am
Raywin
United Kingdom 2001 Defender 90 Td5 HT Java Black
Only had my td5 a year and a half but have done quite a bit of reading on the subject, so when I did my clutch-flywheel I put clear silicone onto the face of the bell housing when I replaced it so if you get a diesel leak then it won't run into the bell housing and contaminate the clutch.
Post #409808 22nd Mar 2015 9:04am
Page 1 of 3 123>
