![]() | Home > Td5 > So I have the engine out and the head off |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Would you take lots of pictures please ?
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 332 ![]() ![]() |
Also I forgot to ask, if I want to de gunk the top of the cylinders can I remove the timing chain completely to crank over the bottom end, clean and then re time by finding tdc of the no 1 piston and re lining up the chain with the one marked link at the bottom and the two marked links at the top?
I can take a few of the head stripped down. and the bell housing. Will get on it before the rugby starts and upload later
Block
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Timing chain did not have the two black links described but two with script engraved that lined up. ![]() Click image to enlarge Head stripped ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge What the rocker cover looked like ![]() Click image to enlarge Cam shaft ![]() Click image to enlarge Injector clamps etc all kept in order ![]() Click image to enlarge Injectors bagged and labelled ![]() Click image to enlarge Leaking FPR ![]() Click image to enlarge Bell Housing gunk ![]() Click image to enlarge Fly wheel ![]() Click image to enlarge Sad Landy ![]() Click image to enlarge |
Inlet manifold nice and clean and no oil in the intercooler. Might put an alisport one on
![]() Thinking of replacing the cooling hoses as they are worn in places. |
![]() Click image to enlarge Other side of the water pump |
I would like to get everything as clean as possible before reassembling, ideas?
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2955 ![]() ![]() |
Dishwasher
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
That's all well and good if you can smuggle it into the kitchen without a certain someone noticing.
Then trying to explain why you have a sudden urge to use the dishwasher all night! How do I know? ![]() Wanted, Forward Control Anything considered. |
I am totally cool with using the dishwasher but Im worried about the internal fuel feed, will it contaminate anything?
just seen this https://www.youtube.com/watch?v=6qs7qsCPabI
Thanks for the pictures - great to see !
If you are ticking off problem areas whilst it's out - you could check the oil pump bolt, uprate the exhaust manifold studs, new o rings in the fuel cooler, and check the oil cooler for corrosion ? |
Love that YouTube ad !!
![]() Though that spanner must have hurt "ouch!" |
Raywin Member Since: 27 Feb 2015 Location: North Yorkshire Posts: 48 ![]() ![]() ![]() |
Only had my td5 a year and a half but have done quite a bit of reading on the subject, so when I did my clutch-flywheel I put clear silicone onto the face of the bell housing when I replaced it so if you get a diesel leak then it won't run into the bell housing and contaminate the clutch.
