Home > Technical > 2014 2.2 oil consumption
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
My 2014 2.2 110 van is going for its first service next Friday, but on checking the oil today (which I've done regularly), I found it to be down to just on the bottom of the dipstick. It's only done 4440 miles from new and this seems rather excessive to me. I've now topped it back up of course.
Last time I checked, I'm certain it was just below the maximum mark. I've not noticed any smoke, but then I've not really been looking out for it. There's no leaks underneath either.
Can I put this down to the engine simply using some oil whilst it's being run in, or is it something I should take up with the dealer next week?
Thanks for any thoughts.
Post #407278 13th Mar 2015 2:42pm
Dave-H
Can't comment on a Defender - But every new Transit I've checked via work [Exact same engine] has always seemed to have oil level on or even below minimum within a few thousand miles Rolling Eyes
I'm not talking 2 or 3 vans here - Feckin hundreds of them Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #407305 13th Mar 2015 4:26pm
Joe the Plumber
Thanks very much. Looks like it's a case of "they all do that Sir."
I'll stop worrying and keep it topped up!
Post #407307 13th Mar 2015 4:32pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I was told by my dealer that it would use 1 litre a 1000miles 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #407373 13th Mar 2015 8:20pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
First 20.000 kilometers never needed to top it up with a single drop. Stopped checking it on a regular basis since then.
Post #407381 13th Mar 2015 8:50pm
Jake the dog
United Kingdom 2014 Defender 110 Puma 2.2 USW Firenze Red
24000 miles in 14 months and not a drop of oil needed to be put in between the two services I've had since new. That's probably the kiss of death Very Happy
Post #407384 13th Mar 2015 8:57pm
LR90XS2011
13000 not used any but is a 2.4 DEFENDER 90 TDCI XS,
Post #407392 13th Mar 2015 9:32pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Used less than 1/4 pint over the 12000 miles I have covered in the last 9 months Thumbs Up 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #407408 13th Mar 2015 10:37pm
pannawonica
Australia
My 2013 Puma 110 has never used any oil between services, and that's in 45deg+ heat! Very Happy
Post #411622 28th Mar 2015 9:22am
Naks
yep, there shouldn't be any oil used on the Puma engines, whether 2.4 or 2.2 --
Post #411633 28th Mar 2015 9:47am
Crawford
United Kingdom 2015 Defender 110 Puma 2.2 SW Corris Grey
Well just to add to the mix. I've just done my first oil change at 1350 miles and only got 6 litres out and that included the oil from the filter. Filled it back up to the max on the dip stick and could only get 6 litres back in!
Only on a Landrover Banging Head
Post #411646 28th Mar 2015 10:19am
dgardel
Italy
Re: 2014 2.2 oil consumption
check the injectors studs Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #412631 31st Mar 2015 10:01am
Spookytooth
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Can only add that I posted a thread on here (last year) because I was worried that my 2.2 Defender (13 plate) was NOT using any oil and was concerned that water or something might be getting in. Consensus at the time was 2.2 does not using oil at any great rate
Post #412711 31st Mar 2015 3:15pm
Joe the Plumber
Thanks for all the replies. My dealer has asked me to monitor how much oil is being used and keep them informed. If it is excessive (and I must admit, I'm disappointed with it), I trust that the warranty will get it sorted out.
Post #412714 31st Mar 2015 3:25pm
dgardel
Italy
let us know Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #412718 31st Mar 2015 3:36pm
