Home > Puma (Tdci) > "False" overheating and limp mode...
Page 2 of 2 <12
dgardel
Italy
Whistle Whistle Whistle Bow down Bow down Bow down Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #407570 14th Mar 2015 7:27pm
ericvv
This is.........
Best mod you can do to your truck, but understand expensive too. You will be surprised by the extra space behind the wheel and lower seating position this gives you.
And, the good thing is that for these Recaros you can also buy the very good quality original LR black seat covers, same type as for the other seat rows. I have those and am very happy with them. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #407573 14th Mar 2015 7:35pm
dgardel
Italy
it is this one, heated, Ambla/Dinamica suede with removable seats base
what about yours? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #407594 14th Mar 2015 8:24pm
ericvv
Daniele, as you know my heated Recaros with removable seat bases came with the SVX as standard, so it is the combination of leather on the sides with the SVX cloth with little Land Rover emblems in the center. From your posted pictures it looks like you got the same Recaro model as the SVX type. Thumbs Up
Give those seat covers a thought. Here is an old picture which I took just after putting them on. They were not perfectly tucked in everywhere yet at that time, so you see more wrinkles than is actually the case now. It is important to properly tuck in the hard stretching bar which is part of that seat cover into the space between the seatbase and backrest part of the seat. That stretches it all up nicely. Forgot how many years they are on my seats now, 4 at least, looking still as new.
Eric
Post #407648 15th Mar 2015 4:38am
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Hi Guys!!
Thanks for all the replies!!!
The valve that I replaced isnīt this one that you suggest.....They sold to me the "white" one....wich is fully open only in 96.....
Will try to find this anoteher one here....and will do the fan spacer too!!!
Best Regards!!!!
Post #408028 16th Mar 2015 2:08pm
munch90
prt thermostats
gray 82c light spring = warm weather thermostat
black 82c hard spring = ok for anyone wanting bit lower running temp in uk
cream 87c medium spring = standard uk fitment
Post #408033 16th Mar 2015 2:15pm
Page 2 of 2 <12
