Home > Puma (Tdci) > Low fuel - misfire
grafty99
Low fuel - misfire
Today on my way to the fuel station my defender started to misfire every 3 or so seconds, it is the first tank of diesel I've put in it as I had been running around on what the dealer had put in.
I had only done 20 miles or so with the light on and when I filled up I got 71 litres in so I assume there would have been 4 litres left (75L tank by the book). Is that low enough for it to start running out?
Or was it the ecu telling me it needed fuel rather urgently?
Also the handbook says I have 2 gallons left when the light goes on and there was I assume 4L left so does that mean that realistically the light means 20 miles left? Shocked 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #405600 8th Mar 2015 1:17pm
charlesteton
When light comes on there is supposed to be 50 miles left in tank and before tank is empty engine will go into limp mode so try and stop driver from completely running out. Apparently it's a big deal if the engine runs dry. We are talking Puma! Smile
Post #405623 8th Mar 2015 2:29pm
Lorryman100
The misfire is the PCM telling you to fill up immediately. I believe there is a section on this in the drivers handbook ?
Post #405740 8th Mar 2015 7:42pm
grafty99
What concerned me most is that the light had only been on for approximately 20 miles of gentle driving, like I said it is the first time I've filled it so no doubt I'll get used to it but it seems like a pretty small warning especially as I'm not exactly close to a fuel station where I live 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #405827 8th Mar 2015 10:42pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
put some fuel in and pop up and show us what ya got.... Putting Dreams on Drives at JLR Solihull..
Post #405841 8th Mar 2015 11:50pm
grafty99
Was going to this weekend but plans changed. Might be coming up during the week next week. I'll have to resist buying some goodies Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #405863 9th Mar 2015 7:18am
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
I ran mine low once to see how far it would go. As soon as it misfired I stopped and put fuel in with a can. I came to the conclusion that you should not expect more than 35 miles from the fuel light coming on.
I have a 90 XS, may be different on loner wheel bases with a different tank.
Cheers, 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #406133 9th Mar 2015 9:48pm
