Home > Maintenance & Modifications > Refurb xs side steps
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Looking at refurbish my xs side steps due to rust ,to do it properly I need to take off the chequer plate tread steps ,but these are secured by very large rivets.
My questions are if I drill these out
Does anybody know where I can get replacements
Can they be fitted at home,they look a bit big for a pop rivet gun
Did think about riv nuts but the tube underneath is round so don't think that would work
Steps look like the below picture
Any help appreciated
Post #403985 3rd Mar 2015 7:48am
Are they large diameter rivets or just large headed?
As an alternative, are there any drainage holes in the lower edge of the tube?
If not you could drill a few underneath where the rivets and replace with button head bolts. Use the holes underneath to feed in the nut & if you want fit blanking plugs afterwards.
Post #404040 3rd Mar 2015 10:26am
Lou Sparts
I think these are large diameter rivets, what you need for these is a lazy tongs rivet tool.
When you refurb you steps be sure to inject some cavity wax or they may end up like mine did.
 2005 Td5 90 XS
Steve
Post #404042 3rd Mar 2015 10:34am
mk1collector
I think mine were long 3/16 rivets so can easily be done with a rivit gun and any local bolt suppliers or even b and q should be able to supply rivets.
Ray
Post #404043 3rd Mar 2015 10:35am
K9F
Stripping tubular sidesteps.....All you need to know with pictures on page 2. Whistle
Rivnuts are the way to go. Thumbs Up
http://www.defender2.net/forum/topic8233.h...p;start=15 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #404044 3rd Mar 2015 10:37am
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
How convenient - I just took mine off to sort out the start of some rust, but was wondering how to fit the chequer plate back on...
One additional question - are these things r/l handed? I forgot to mark which step came off which side! Embarassed
Post #404863 5th Mar 2015 11:04pm
K9F
Evening Eutek,
110 ones looking at the photos on page 2 of the link I posted above appear to fit either way round as the brackets seem to be a mirror image at each end. Offer them up and see how they fair where they attach. 90 ones are different and only go one way as the brackets at each end are different.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #404864 5th Mar 2015 11:18pm
eutek
Super - thanks, was looking at them and they appeared to be the same on both ends, will try later after I strip them down and re-paint.
Post #404930 6th Mar 2015 9:36am
eutek
Ray
Hi - do you have a link for the type of rivets you used?
I drilled the ones in the side steps out today and they're rather big, doubt my mr. happy shopper manual rivet tool would be up to the task, will most likely need to get a bigger one.
Post #405187 6th Mar 2015 9:48pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Hi all,
just stripped my side steps off my truck to clean up.
bolts are all pretty sh*gged (rusted / rounded etc).
They seem to be unusual in that they are M8, but have a metric 10mm hex head.
I would normally say, sod it and ram in some std M8's, but the locations for some of the bolts are close to obstructions (supports into the chassis for example).
Any feedback on this?
I'm tempted to use stainless cap head screws with washers.......
Andy
Post #619128 24th Apr 2017 1:55pm
nidge n
Does anyone know if the rubber surround is available? Mine has come away from the tread.
Thanks all
Post #619575 26th Apr 2017 6:44am
ROBBONTHEROCK
Ok, so I have stripped back and cleaned off the old paint and rust debris with my new grinder and wire brush attachment.
I sprayed with some farten to kill any rust particles, now its drying.
I am planning on using the halyards truck bed liner as the paint.
But the alloy tread plate and the rubber plinth has had better days. Any ideas for options on cleaning thing up?
Andy
Post #620914 1st May 2017 9:48pm
