Home > Puma (Tdci) > It has happened AGAIN !!!
Page 2 of 5 <12345>
bell-auto-services
From the pumps I've been told about that have failed they are mechanical failures in respect that the veins have warn out due to lack of lubrication in the oil it's self, or that the pick up pipe is blocked and starved it.
How accurate that info is I'm not exact on but still food for thought even if not the exact cause.
It's a shame we can't get hold of a failed pump or a few and a new one to make comparisons from directly.
Post #403370 1st Mar 2015 2:56pm
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
On the Mazda I had sight of it was definately blockage of the strainer, leading to oil starvation that caused the failure.
However I can imagine oil running with up to about 10% diesel mixed in it and a shed load of carbon causing hell for the oil pump too.
Did somebody on here once say that the 2.2 has a variable displacment pump, to save fuel.....
I can't see the oil pumping loses being significant, but can believe they fitted said pump, lowering oil pump output to me just sounds ridiculous.
Jonno
Post #403371 1st Mar 2015 3:04pm
grizz
2014 Defender 110 Puma 2.2 XS CSW Corris Grey
I own a garage and specialise in vw & Audi repair , tuning . Over the past few years we've seen lots of 2.0 tdi engines with oil pump problems .
The early engines had a oil pump driven via a chain . On these the chain tensioner would fail causing the chain to slip on the oil pump sprocket .
The later engine used a gear driven oil pump . These also have had plenty of failures due the the pump shaft becoming worn resulting in no oil pressure .
Most of the time a repair is possible .
We have replaced lots of oil pump pick up pipes on the older 1.8T engines as they block with sludge ...
Does anyone know what the exact problem is with the ford engine ??
Post #403374 1st Mar 2015 3:08pm
munch90
yep its a variable displacement pump and as far as I know its a concentric pump not a vane pump
and the few ive seen and heard about were drive failures
Post #403375 1st Mar 2015 3:09pm
Jonno
Not on a Defender or Transit, however this is a pic I came accross on the Mazda forums when researching their engine issues.
The strainer on the engine in question was the same....full of carbon.
Post #403378 1st Mar 2015 3:16pm
bell-auto-services
Wow that is bad. This for sure was a starvation problem Sad
Post #403381 1st Mar 2015 3:25pm
grizz
So the failure could be down to lack of oil flow due to a blocked oil pick up .. I would recommend the use of a good oil flush at every service ..
Change the oil every 5k and replace the oil pick up every 20k
Post #403382 1st Mar 2015 3:25pm
Jonno
Apparently the standing advice for these Mazdas is regular oil changes and sump removal every 12-18 months to clean the strainer..... how easy it is to remove the sump I have no clue.
Jonno
Post #403383 1st Mar 2015 3:28pm
bell-auto-services
Looking on Topix the pump is chain driven. No updated chain or tensioner. No updated pickup pipe. Yet FOUR part number changes for the pump it's self Shocked
Post #403385 1st Mar 2015 3:29pm
Jonno
It would be interesting to see in one of the Ford 2.2s when the sump is removed after oil pump failure, to see if we are getting the same clogging issues.
The first that my friend with the Mazda knew was the oil light flickering, then 400 metres further down the road seizure.
Jonno
Post #403387 1st Mar 2015 3:32pm
Jonno
Obviously a weakness or two identified in the pump then. By the sounds of it they don't know how to fix it.....
I think if I had a engine that failed out of warranty I'd be suggesting legal action to get a LR contribution, as there is obviously some issue. LR can then take it up with Ford...
This and the filthy oil issues that can happen doesn't bode well.
Jonno
Post #403389 1st Mar 2015 3:35pm
bell-auto-services
Though I've not removed a sump from a 2.2 I do have an engine out from my 3.2 build and even on the car it looked easy to do.
My Ford Ranger is at 5k miles now so I'll drop the oil soon and have a look with the camera in the sump for any debris.
LR029912 is up to ca444444
LR036454 is from ca444445 to da444246
That part number changed to LR055351 in Same vin range
Then LR058095 is for da444247 on wards, all these part numbers now supersede to LR058095
Post #403390 1st Mar 2015 3:36pm
grizz
On the Audi engines I've always put it down to "long life serving " that's a terrible idea to let a engine go for 2 years or 20k without a oil change ..
Post #403391 1st Mar 2015 3:38pm
bell-auto-services
I agree with you. Long life servicing can not be good at all.
Post #403393 1st Mar 2015 3:40pm
Jonno
yup long life servicing, fuel contamination of the oil and even the EGR recycling *rap back into the engine doesn't bode well for a long life engine !
Jonno
Post #403395 1st Mar 2015 3:42pm
Page 2 of 5 <12345>
