Home > Land Rover Customer Relations > 2.2 TDCI Recall for oil pump failure
Page 5 of 7 <1234567>
oburrill
United Kingdom 2013 Defender 110 Puma 2.2 SW Corris Grey
On the day when questioned they said only the oil pump, filter and oil were changed.
I questioned them and emailed the list as shown on here. They've now sent me an invoice with the parts as per the list on here.
But as mentioned the sump doesn't look like it has been changed, and on the day they said it hadn't, but when questioned now they say it has and the invoice lists all the parts.
The invoice of parts isn't proof that all these parts have been fitted.
It's going back in at the beginning of June and they said they'll get it up on the ramps and have a look. With work and commitments I only have certain days when I can take it in.
To be honest, i'd want the sump off and all the part checked. They've probably changed what they said, oil pump, oil and filter, but not the other parts on the list, so really they should replace the sump, the parts that haven't been changed and a new filter and oil.
We'll see what happens. Is it possible to have a recall on a recall?
Post #425129 20th May 2015 3:12pm
Have you sent them the photo. I'd crack on with this now by phone/email as the longer you leave it the easier it is for them to play the amnesia card.
Post #425142 20th May 2015 4:46pm
Also are you sure it's an invoice they have sent you? Who's it addressed to?
Post #425145 20th May 2015 4:48pm
oburrill
I'm going away so it is difficult to sort out sooner now with commitments.
The invoice was to me with my name and address. This is because I wanted it in writing what was done and fitted. On the day he thought it was just oil pump, oil and filter. Now when I questioned it he sent me the invoice, it details the list of parts that "should" have been fitted, sump included. Yes, I've sent them a photo.
Thanks.
Post #425150 20th May 2015 5:13pm
Pickles
Excuse my ignorance, a mechanical dummy is speaking.
Where is the oil pump on the Puma engine, on the side of the engine or inside the sump area?...Surely if the sump had to be removed, not fitting a new sump doesn't make any sense, although it is quite obvious in the pics that the old sump has been re-used?
Pickles.
Post #425236 20th May 2015 9:46pm
1 Oil cooler
2 Oil filter
3 Oil pressure switch
4 Feedback tube
5 Oil pick-up tube
6 Dipstick
7 Oil pump
8 Secondary drive chain
9 Turbocharger oil feed tube
10 Dipstick outer tube
11 Turbocharger oil drain tube
12 Oil temperature/low level sensor
Post #425269 21st May 2015 7:49am
Pickles
So all the stuff that has to be replaced is inside the sump, so how stupid is it not to replace it?
Pickles.
Post #425281 21st May 2015 8:46am
Jim_Bean
Who was the dealer?
They definitely should have replaced the sump. Have you tried the Land Rover contact on here?
User name is Ryan@LandRover. He should be able to contact the dealer on your behalf. It makes no sense as they will have been provided the parts in a kit from Land Rover and call claim for the time and parts against warranty anyway.
Why wouldn't they replace the sump? Did they actually replace anything? That would be my concern.
Dodgy dealer.
Post #425282 21st May 2015 8:51am
CRC@LandRover
Verified Account
Verified Account
Hi oburrill
Thank you for your PM.
I am in the process of looking into your concerns and will respond via PM shortly.
Regards
Ryan
Post #425289 21st May 2015 9:22am
Pickles
Supacat wrote:
1 Oil cooler
2 Oil filter
4 Feedback tube
5 Oil pick-up tube
6 Dipstick
7 Oil pump
Supacat, that is a very helpful image.
Pickles.
Post #425293 21st May 2015 9:27am
oburrill
Hello, this has all been sorted now. All the parts HAVE been replaced.
1. When they do this job the sump is damaged when removed, hence the new sump to be fitted.
2. As the technician wanted to ensure the job was done to the highest standard, as my vehicle was waxoiled including the sump, when he finished the job he took it over to their body and paint shop and sprayed some waxoil on it to stop it going rusty. It is great to know that there are people willing to go the extra mile with a job like that.
3. I have see photos on my old waxoiled sump and the other parts.
I could have done with some of these answers earlier, but everything is clear now. I am also pleased to know now how much pride the technican takes in his work to do extra things like this, i just wish they had mentioned it and it took several days to find out.
Thanks.
Oliver.
Post #425491 22nd May 2015 8:31am
Pickles
Top result for you, & top service by your dealer.
Pickles.
Post #425504 22nd May 2015 9:22am
lohr500
At the risk of starting a conspiricy theory, if your earlier photo is the one of the sump that they say they waxoiled for you then I would still be doubtful. It looks to me like a sump that caught a bit of overspray from the original waxoil treatment rather than one which had been taken to the body shop for a good coating . Also the photos of new sumps posted here and as fitted to mine are shiny black. Your "replacement" looks grey. It could be the photo or there may be different sump colours out there but again I would still have doubts. If you wipe off a small area of waxoil with a bit of petrol on a rag, is there a shiny black sump underneath?
Post #425512 22nd May 2015 9:41am
YOLO110
Australia
Mmmm. Rolling Eyes
Just an observation...
Your 'wax oiled' sump has had lots of great 'sealant' applied in the joint area. Thats not normal practice or should be necessary with a new sump and new gasket fitted...
By comparison, the photo of the 'shiny black sump' has no sealant visible on the joint... as it should be... Smile YOLO... You Only Live Once...
Post #425601 22nd May 2015 5:35pm
K9F
Your 'questionable' sump and the very shiny one in the previous post appear to have numbers stamped on them underneath and the service recall list also has a part number on it. Why not placate the people who are questioning the origin of your sump by checking the number and asking Jim Bean to do the same? If the numbers tally job's a goodun! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425615 22nd May 2015 6:28pm
