![]() | Home > Maintenance & Modifications > Rear winch |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
My old truck, was it like this??
NickH Member Since: 01 Nov 2014 Location: Halifax Posts: 204 ![]() ![]() ![]() |
I can make you one like mine, It bolts on to the rear x member and has a 2" receiver built in.
I am on a different computer so I will post pics in the morning. ![]() 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Easier way is to fit via a Devon 4x4 rear winch cross member
http://www.devon4x4.com/index.php?page=sho...;Itemid=14 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Ours
![]() Click image to enlarge A rear winch in many ways is better then a front winch ![]() Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 ![]() ![]() ![]() |
Yes, exactly like that. |
It was built by Devon, it was literally a letter box cut into the x-m, they since developed what Tim posted up, though it's easy enough to do
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
The rear petrol tank from td5 onwards limits how flush you can get it though - and I'm not sure about having one stick out as far as it would need to ...
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2955 ![]() ![]() |
North offroad used to do a nice weld on mount but stopped production for some reason
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I have a problem with the letter box style.
When Land Rover designed the rear cross member with all the holes in it it had to have a type approval. Now if you had a rusted hole that size it would be a M.O.T. failure so how do get a pass with the same size hole deliberately cut into it? Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
If you are going to all that effort could you make one like the Ibex that could run out to the front or the back?
Or you can just rig your front winch for a rearwards pull an save all the effort? |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
There's always the 2" receiver option which you can put on the front and the back.
This way you only need 1 winch for either end, and keep it in doors when not used, which keeps it clean. Of course you won't have the "look" but if that's your main objective you wouldn't probably be interested in the back winch anyway. Not to mention the extra cost in case of an accident... |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8153 ![]() ![]() ![]() |
rear tank as mentioned is biggest issue.
rear winches also tend to get a lock more crud in them than front (usually lower down) and how many times do you end up stuck part way up something with the rear sat in the mud a while. plus vac at rear driving doesnt help maintain it. cl2 option is a good practical way around it but depends on how often you are going to need it and if you envisage needing to operate two winches at once. (ie front and rear) Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Heres mine, done , fitted and tested winching a tractor and muck spreader out !
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2003 Td5 90 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 ![]() ![]() ![]() |
Thanks Zone30, that's good to know. As it happens I prefer the look of the Bowler bumper and was wondering how a winch might fit (if at all) but that it might ruin the look of an expensive item. Maybe this would be the way to go....? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
