Home > Puma (Tdci) > Surely this can't be right? |
Wrong indeed, at least surely so for the hazard light switch and the headlamp height adjuster. My dealer also could not find the part number for those bulbs as they are not on the Puma microcat anymore. If I remember well, they are listed for the Td5 or even older. You can order these bulbs from one of the aftermarket suppliers. There is an older thread on here about where I asked your very same question, and someone steered me in the right direction. I ordered several of those little bulbs then, and let my dealer install them. Sorry I cannot easily look up that thread as am traveling with iPhone only. Do a search for hazard light bulb and you probably will find the thread.
Edited - found the thread, do a search for: hazard light switch illuminated or not. Bulbs are shown and available from rimmerbros. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
11th Feb 2015 10:09pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
I know Ring do them any good motor factor should have a selection box of them. You'll need to take them out first as it'll be a case of matching them.
11th Feb 2015 10:14pm |
AndyLloyd Member Since: 03 Feb 2015 Location: South Cheshire Posts: 11 |
Ahhh excellent....many thanks! Thought it didn't make sense!
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 596 |
Any info on the clock?
12th Feb 2015 9:39am |
