Home > Puma (Tdci) > Surely this can't be right?
AndyLloyd
England 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
I went along to my local Independent Land Rover garage this morning to get bulbs for the interior clock, hazard warning light switch and the headlight beam adjust switch....I was told that it's impossible to change the bulbs....surely not?
Post #398015 11th Feb 2015 9:50pm
ericvv
Wrong indeed, at least surely so for the hazard light switch and the headlamp height adjuster. My dealer also could not find the part number for those bulbs as they are not on the Puma microcat anymore. If I remember well, they are listed for the Td5 or even older. You can order these bulbs from one of the aftermarket suppliers. There is an older thread on here about where I asked your very same question, and someone steered me in the right direction. I ordered several of those little bulbs then, and let my dealer install them. Sorry I cannot easily look up that thread as am traveling with iPhone only. Do a search for hazard light bulb and you probably will find the thread.
Edited - found the thread, do a search for: hazard light switch illuminated or not.
Bulbs are shown and available from rimmerbros.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #398027 11th Feb 2015 10:09pm
NickMc
I know Ring do them any good motor factor should have a selection box of them. You'll need to take them out first as it'll be a case of matching them.
Post #398029 11th Feb 2015 10:14pm
AndyLloyd
Ahhh excellent....many thanks! Thought it didn't make sense!
Post #398030 11th Feb 2015 10:14pm
Stiff1
Any info on the clock?
Post #398080 12th Feb 2015 9:39am
