![]() | Home > Tdi > Coolant issues |
Could be an airlock
I had exactly the same on my 300 Lots of guides on the net how to fix |
Bows Member Since: 07 May 2012 Location: Wales Posts: 521 ![]() ![]() ![]() |
I had a fiddle with the connections of the temp sensor and gauge now works, it remains steady and heater still keeps blowing warm air.
I just can't relax with the water in the header tank remaining so cold. Thanks for your reply, I'll investigate for airlock. Thanks |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Coolant in the expansion tank normally is cool mate. Wouldn't worry too much
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
There are two small hoses that join into one at a round Y piece going to the expansion tank. These can become totally blocked, give them a good flush through. I have known three cars that this happened on. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
^^^^ agree with checking the small (self breeding/return ) pipes , can cause air lock problems
also might be worth checking its got the right thermostat fitted some thermostats have a extra spring loaded washer on the bottom if that's missing it can cause odd things to happen |
Thanks for your replies, the garage is an established Land Rover specialist therefore I'd hope the thermostat is correct
![]() I've taken it back there now so we'll see what it's like when I get it back, Thanks guys |
Had it back now, "p" gasket changed and everything seeems fine now! (Touches wood)
Thanks for all your advice. |
