![]() | Home > Maintenance & Modifications > Which one is the flasher relay?!? Tdci |
Crafty1980 Member Since: 21 Jul 2014 Location: Norfolk Posts: 74 ![]() ![]() |
Just upgrading my indicators to LED. Need to change the relay.. Not sure which one it is though?!?
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
I know I'm going to regret this, but why does it have an adjuster on the top?
Merlin |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5823 ![]() ![]() |
Because LED indicators have been fitted.
![]() Andy |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
If you change the indicators to LED you can adjust the relay so the trailer check light on the dash only flashes once (as it should) when the indicators are flashing. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20652 ![]() ![]() |
You can use the RDX relay with or without LED's if you wanted.
If you have LED's it's a must to adjust the flash rate and a bonus of setting the traier light correctly. If you have trust incandescent lights it'll work too no problem and you should still be able to adjust the trailer light better than OE. |
Thanks Ian! Very helpful.
