Home > Maintenance & Modifications > Which one is the flasher relay?!? Tdci
Crafty1980
Just upgrading my indicators to LED. Need to change the relay.. Not sure which one it is though?!?
Post #396654 7th Feb 2015 12:31pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Top left hand corner, see the one with the adjuster on the top.
Glad I checked as one of the factory taped in fuses had fallen out!
Ian 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #396660 7th Feb 2015 12:48pm
Merlin
I know I'm going to regret this, but why does it have an adjuster on the top?
Merlin
Post #396666 7th Feb 2015 1:20pm
landy andy
Because LED indicators have been fitted. Thumbs Up
Andy
Post #396669 7th Feb 2015 1:26pm
VeeTee
Netherlands
If you change the indicators to LED you can adjust the relay so the trailer check light on the dash only flashes once (as it should) when the indicators are flashing. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #396670 7th Feb 2015 1:27pm
You can use the RDX relay with or without LED's if you wanted.
If you have LED's it's a must to adjust the flash rate and a bonus of setting the traier light correctly.
If you have trust incandescent lights it'll work too no problem and you should still be able to adjust the trailer light better than OE.
Post #396675 7th Feb 2015 1:50pm
Crafty1980
Thanks Ian! Very helpful.
Post #396891 8th Feb 2015 8:40am
