Home > Puma (Tdci) > Puma bonnet release - heads up re. bonnet thefts
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
The following was posted on the LandyWatch forum yesterday. I'd heard/knew about the radiator grill trick and the approach to combat it but just like the OP, I wasn't aware of the wing top blanking plate approach. Just thought it might be a useful heads up....
Posted on LandyWatch 1/2/15 wrote:
I posted a discription of the bonnet theft from my 110 Puma, I was aware of the bonnet release cable being pulled through the radiator grill to release the bonnet, I had my release cable running through a steel tube to prevent this, what I wasn't aware of was that if you remove the air vent blanking plate from the drivers side wing, it's only held on by a few screws, the release cable runs directly under this cover and all you need to do is pull cable out of it's plastic fixing clip give it a pull and bingo the bonnet is released, this is how they got my bonnet open, I've never heard this mentioned before, is this a common known fact ? or is it something that needs mentioning, when my new bonnet is fitted I intend to blank the vent aperture off with a piece of metal plate and pop rivet in place.
A quick search on here using the term "Puma bonnet security" will throw up lots of discussion threads about various makes of security hinge and indeed the "bike lock through engine lift eye and bonnet reinforcement braces" thread started by Noworries... http://www.defender2.net/forum/post68469.html Jon - 110 td5 [sold]. Currently Defenderless.
Post #395264 2nd Feb 2015 8:55pm
leeds
It is also made worse by some conversion companies replacing the plastic blanking plate with a open wire mesh. A quick hook???
Plastic plate can be broken with a quick hammer blow so use a solid metal one and body filler in the screw heads.
Another alternative is a solid ali wing top. OK might look odd as a non matched pair.
Brendan
Post #395278 2nd Feb 2015 9:12pm
also use dome headed screws on the top of the plate and secure from below Whistle
Post #395378 3rd Feb 2015 8:26am
charlesteton
Great!!! Had cable put in stainless steel rod by latch so could not pull, nothing thing to worry about. At least I know how to open bonnet if latch gets Censored ! Been in my head, for a while, to get heavy weight padlock and hasp put on bonnet/wing anyway.
PS Cheap way to make it slightly more difficult is to drill out screw/hex head part of bolts. Yes, I know there are tools to get around this but its worth a punt!
Post #395391 3rd Feb 2015 9:20am
wyvern
gents ...... is this a good thing to tell everyone how to open the bonnet on the open forum ... ?
maybe edit this to have the info not visible
you never know who is reading it ...
Twisted Evil Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #395477 3rd Feb 2015 3:40pm
JWL
Don't you think that the scroats allready know the different ways to get into a Defender, I for one would much prefer to see these type of posts so that all owners are aware of the vulnerable points on their motors.
Post #395483 3rd Feb 2015 4:11pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
I for one didn't know the access points Embarassed
But there's hinges and lock on mine
Might need to think about the others now It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #395495 3rd Feb 2015 5:14pm
Grenadier
I might be being a little dim, but (luckily) there's not too much theft over here. As such, is this actually theft of the 'bonnet' or merely ingress for theft of the vehicle as a whole? Shocked Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #395506 3rd Feb 2015 5:42pm
JWL
Bonnets and doors are often taken leaving the motor behind. Doesn't take many minutes to whip them off with the right tools.
Post #395514 3rd Feb 2015 6:03pm
leeds
That is exactly why our local police was marking those parts at the weekend!
Brendan
Post #395521 3rd Feb 2015 6:22pm
SGH
Brendan
Or fit one of these...
Post #395539 3rd Feb 2015 7:09pm
leeds
Made by Stefan of GMB, called a fender locker and sold in the UK by Kevin of Mudstuff HERE
Brendan
Post #395545 3rd Feb 2015 7:21pm
Venomator
Brendan
I like the idea of the lockers a lot... Thumbs Up
But the external hinge and raised lock are a big fail for me... Shocked
Just me being picky perhaps, but how much better would it be if the hinge was hidden and the lock sunken into the top with a cover fitted, especially given the asking price... Whistle
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #395548 3rd Feb 2015 7:37pm
Those lockers are also too big to go through most wing top chequer plate panels
Post #395565 3rd Feb 2015 8:37pm
leeds
Brendan
Post #395568 3rd Feb 2015 8:45pm
