Home > Td5 > Brakes could be better
Page 2 of 2 <12
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Thanks munchy I'll give that a go in the morning.
I'm not saying the servo has gone but they just don't seem great.
Edit - I've just remembered something else I'll have to check, as I've removed the EGR and all the gubbins with it, I've blanked the 'T' off that goes to the EGR from the brake pipe with a short piece of pipe and a bolt with silicon , I'll also check that's not leaking somehow.
Post #397113 8th Feb 2015 10:29pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
Lambley
The brakes are superb, they will lock up without excessive force now. Before you could stand on the pedal and it was rock hard but the landy just pulled up slowly. I moved a friends trailer (2 tonnes) and it had no brakes, it just pushed me and I nearly went through a wall....very scary ! so I knew I had to investigate this issue.
I got the servo from Ribble valley 4x4 and I think its a TRW/oem one.
I hope you can see the crack on the pic.
 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #397242 9th Feb 2015 12:48pm
Lambley
Thanks NickH - I've had a look today and surprise surprise......
I'll get one on order, thanks for the info mate Thumbs Up
Post #397322 9th Feb 2015 3:50pm
NickH
Thats the one.
Like I say, be careful when you have fitted the new one....I nearly sent the dog through the windscreen Rolling with laughter 2003 Td5 90
2013 sport hse
Post #397351 9th Feb 2015 5:14pm
Lambley
I'll let the wife test drive it first then Rolling with laughter
Post #397358 9th Feb 2015 5:41pm
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Hmmm this is interesting, same on a family member's 90 TD5. Had new discs, pads and calipers and it's still not great.
Out of interest, what part number is the servo for a TD5 non-abs? At only £50 a pop it's worth doing on a punt.
Thanks!
Post #397368 9th Feb 2015 6:46pm
munch90
first one I come across cracked was on a mates defender , see quite a few do it now
Post #397369 9th Feb 2015 6:50pm
Lambley
Part number is STC4322.
Mine's an 06 but it's only done 34k miles, I'm sure it's been like that for a year or so too.
Post #397371 9th Feb 2015 6:57pm
Freypal
Brilliant, cheers chap.
This is a 56 plate and around 80k miles so sounds reasonable!
Post #397375 9th Feb 2015 7:16pm
Lambley
Just finished fitting and test driving after fitting a new servo, I have to say the difference is massive! I honestly didn't know that the brakes were as bad as they were. I'd say they have getting on for twice the stopping power of previous.
Thanks to all the replies, especially NickH for the info and picture Thumbs Up
Post #398175 12th Feb 2015 5:27pm
Freypal
Right ordered one so will see how i get on. Should be able to fit in a few weeks and try! will report back...
Post #398219 12th Feb 2015 7:28pm
Page 2 of 2 <12
