![]() | Home > Td5 > Brakes could be better |
NickH Member Since: 01 Nov 2014 Location: Halifax Posts: 204 ![]() ![]() ![]() |
Lambley
The brakes are superb, they will lock up without excessive force now. Before you could stand on the pedal and it was rock hard but the landy just pulled up slowly. I moved a friends trailer (2 tonnes) and it had no brakes, it just pushed me and I nearly went through a wall....very scary ! so I knew I had to investigate this issue. I got the servo from Ribble valley 4x4 and I think its a TRW/oem one. I hope you can see the crack on the pic. ![]() Click image to enlarge 2003 Td5 90 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Thanks NickH - I've had a look today and surprise surprise......
![]() Click image to enlarge I'll get one on order, thanks for the info mate ![]() |
Thats the one.
Like I say, be careful when you have fitted the new one....I nearly sent the dog through the windscreen ![]() 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
I'll let the wife test drive it first then
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 ![]() ![]() ![]() |
Hmmm this is interesting, same on a family member's 90 TD5. Had new discs, pads and calipers and it's still not great.
Out of interest, what part number is the servo for a TD5 non-abs? At only £50 a pop it's worth doing on a punt. Thanks! |
first one I come across cracked was on a mates defender , see quite a few do it now
Part number is STC4322.
Mine's an 06 but it's only done 34k miles, I'm sure it's been like that for a year or so too. |
Brilliant, cheers chap.
This is a 56 plate and around 80k miles so sounds reasonable! |
Just finished fitting and test driving after fitting a new servo, I have to say the difference is massive! I honestly didn't know that the brakes were as bad as they were. I'd say they have getting on for twice the stopping power of previous.
Thanks to all the replies, especially NickH for the info and picture ![]() |
Right ordered one so will see how i get on. Should be able to fit in a few weeks and try! will report back...
