Home > Puma (Tdci) > Some photos about detail of my Defender
Page 2 of 2 <12
hi DG,
my cubby underbox turned up today and fitted it in 15 minutes, what a difference !
cheers
Post #34793 21st Jun 2010 5:51pm
dgardel
Italy
Happy to give you a good idea Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #34813 21st Jun 2010 9:07pm
harveyg77
What's a cubby box under tray?
Thanks Harvey
Post #34817 21st Jun 2010 9:26pm
alantd
Thanks Harvey
It's a lockable safe that fits under the cubby. Not only is it lockable but, installed correctly, nobody knows it's there. Thumbs Up One that started out as a 2.4 TDCi 110 XS
Post #34822 21st Jun 2010 10:05pm
harveyg77
Sounds useful, where can you get one from and how easy are they to fit?
There is a void under both front seats in my Defender (ones got a jack and battery, the other some thing else, possibly fuse box, I can't quite remember), is there the same void under the cubby box then?
Thanks Harvey
Post #34826 22nd Jun 2010 6:26am
Thanks Harvey
no, under your cubby box is your transfer box, but the undercubby box brings a standard LR cubby box up by about 100mm so it's also an arm rest
they are on ebay or from www.offroadservice.de (see http://www.shop.offroadservice.de/popup_image.php?pID=316)
Post #34885 22nd Jun 2010 5:48pm
landroverdiver
Hi
very nice truck.
I have had a look on the web site for the parking sensors. I am going to buiy the same set you have, but I notice from the Dolphin website that the sensors may not work properly if mounted on steel. Is this correct? I was thinking about mounting the outer two as you have, on the ally panel, and the inner two straight onto the rear crossmember. Or is this why you have mounted the inner ones on brackets?
Thanks
mike
Post #35004 24th Jun 2010 9:56pm
Gav110
Australia
Thanks Harvey
Here in Australia Mulgo sells on which is more useful than the usual safe - called an "ExBox" - with mounts to take the ABS and relays from under the drivers seat. This allows you to free up that space for storage, plus there is room left over in the ExBox after fitting the components for some storage plus it locks.
See: http://www.mulgo.com.au/p13_Mulgo-Ex-Box.html
Gav Gavster
2010 Puma 110
Post #35092 26th Jun 2010 9:38am
alantd
I mounted those parking sensors a couple of weeks ago - thanks DG for the inspiration - it took me about an hour (mostly because a passing workman was absolutely fascinated and wanted a blow by blow account).
They're absolutely fabulous - I would say a must-have addion for everybody. Even more so at £30!
Found their limitation this morning though: was relying on them and reversed into a lamp post. No damage , of course. I only fitted 2 sensors and it's my own stupid fault for not paying attention. They really come into their own when reverse parking. Awesome! One that started out as a 2.4 TDCi 110 XS
Post #36098 13th Jul 2010 7:08am
dgardel
Italy
I'm happy Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #36106 13th Jul 2010 9:01am
dgardel
Italy
Now added the JWSpeaker 8700 7" round FULL LED Headlamps upgrade
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #36108 13th Jul 2010 9:12am
Page 2 of 2 <12
