Home > Puma (Tdci) > Digital Tachograph Buying & Fitting recommendations
Page 2 of 2 <12
dorsetsmith
blackwolf wrote:
I think you mean 3500kg not 2500kg.
YES Whistle
Post #394424 31st Jan 2015 3:03pm
dorsetsmith
Xelr8 wrote:
Thanks for the suggestions so far.
I have been quoted 1550 fitted so far but I was hoping to get it a bit cheaper Whistle
T Thumbs Up hat Right
Post #394425 31st Jan 2015 3:04pm
22900013A
When I had mine fitted it was about 1500ish all-in.
Mine was mounted on the side of the cubby box, but a better idea would have been to move the lid back and mount the tacho inside the cubby. The lid being moved back leaves a gap so you can see the unit, you MUST be able to see the unit when driving.
Ref exemptions for public utilities, this is not actually correct, the exemption is dependant on the work they are doing, emergency repairs is exempt, new works for profit is not. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #394711 1st Feb 2015 9:35am
We sell a lot of this cubby to users installing Tachos
Post #394730 1st Feb 2015 10:07am
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
My pereferd location. But ordered mine with the sub on the cubby, guessing shouldn't be to difficult to swap
Post #394933 1st Feb 2015 7:58pm
Very easy, four small bolts through the rear
Post #394934 1st Feb 2015 8:00pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
You will need to add a tachograph warning light with the drivers field of vision if mounting the tacho in the cubby box area
Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #395016 1st Feb 2015 10:45pm
Page 2 of 2 <12
