Home > Maintenance & Modifications > Crystals or Xenons? |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 |
It looks good value, it cost me £35 (including postage) to buy decent quality bits from Polevolt to do myself, using the list provided by someone else on here. Remember to add postage if that is all you are buying. 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
31st Jan 2015 6:43am |
Rosso_NI Member Since: 09 May 2014 Location: NI Posts: 275 |
Crystals with decent bulbs get my vote
31st Jan 2015 7:08am |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
If Crystals are so much better than the standard headlamps unit, why do Land Rover supply the standard one?
Most of the time there's a compromised, like brighter bulbs not lasting as long, but what is the compromise with Crystals? |
31st Jan 2015 9:09am |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 |
I guess it would probably help if you looked at the links to the 2 options my husband was referring to.
LED"s not an option as we are going to having some very expensive new seats http://www.flatdoguk.com/wipac%2Dcrystal%2...amps%7E493 or http://www.flatdoguk.com/xenon%2Dultima%2D...rhd%7E1021 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic 2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) |
31st Jan 2015 9:41am |
http://www.autoexpress.co.uk/car-maintenan...non-ultima
I'm not saying it's right or wrong, but I was planning on getting LED headlights but have had cold feet at the cost (sorry Brendan). What I've done instead is bought this: http://www.paddockspares.com/boomslang-per...-loom.html at £27.60 http://www.paddockspares.com/pm678-wipac-c...ralia.html at £33.49 and http://www.amazon.co.uk//dp/B00EPLCP3U for £14.66 For a total of £75.75. That compares favourably to £500 for a set of LED headlamps, though won't be as good and will use more power. Whether LEDs are 6 times better I'm not sure, but I'd have been upgrading the wiring anyway so at worst I've wasted £50 plus a bit of time. When I fit them next weekend I'll try and do some comparison measurements of volts to the lamps and light output measurements before and after, though numbers from a lux meter are difficult to compare as they don't take the whole beam in to account. |
31st Jan 2015 11:51am |
