Home > Td5 > Front Seats..
Page 2 of 2 <12
timtom1
United Kingdom 2001 Defender 90 Td5 CSW Alveston Red
They held the seat rails so there are very long bolts at the front I will find some replacement shorter bolts as they are very loose otherwise, thanks for the reply Thumbs Up
Once its all back together I will upload pics 2001 90 TD5 CSW Alveston Red Manual
Post #396906 8th Feb 2015 9:26am
timtom1
oh dear!
so I installed the cubby box with the mounting feet. Then realised I couldn't get to screw the metal plate back to the base, I did it by hand on one side (marked in red) however the thing it screwed into dropped out when I took it for a test drive. so there is now a perfect 2cm round hole.
Any suggestions, just use washers and bolts?
Tim 2001 90 TD5 CSW Alveston Red Manual
Post #397018 8th Feb 2015 4:45pm
michaelwl
South Africa 2002 Defender 110 Td5 SW Alpine White
Hi Tim,
Just get some Rivnuts, clinch nuts, captive nuts, whatever they are called in your part of the world and fit them into the hole you now have.
Then screw straight into them.
Thumbs Up 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer
2013 Discovery 4 XS
Post #397189 9th Feb 2015 8:29am
timtom1
I found it still attached to the plate, random!
well after two hours and readjusting some holes its finally in! I would like to say its been an easy task but some of the bolts were rounded and had to be drilled out, its was just very fiddly trying to line the bolts up but I managed it in the end Smile
Post #397435 9th Feb 2015 8:05pm
Page 2 of 2 <12
