![]() | Home > Tdi > +2" lift kit brake pipe advice |
I would go for extended brake lines at least in the front I don't think it's needed in the rear.
I you want to save a little you might be able to lower the on the chassis and modify the plate on the caliper side. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
What are you doing about your propshafts?
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8213 ![]() ![]() ![]() |
Llama 4x4 i use for all my pipes, excellent product. consider banjo fittings straight to caliper too. search for other thread on here about it. Cheers
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17718 ![]() ![]() ![]() |
Bearing in mind the relatively insignificant extra cost, and the realtively insignificant additional effort to fit, I would definitely fit extended hoses. Not worth the risk, especially if they are short you could well rip out both circuits in a single incident.
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Why, i didn't think i needed to ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
Watch part six of a 4x4 is born, helpful info.
you can get plates from paddocks to extend your props as well |
