Home > Wheels & Tyres > Best tyre option and why |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
I'm probably sounding like a stuck record, but wide tyres are really not my thing.
The vehicle that had most issues getting off a field I was in last year was a 4X4 with wide tyres on it, and that was including a few of us with trailers and loads of 2wd cars. Unless you need flotation, wide tyres give you the hillbilly look, are worse on and off road, put more stress on everything, make the steering heavier, make the fuel consumption worse, cover your sides with mud, make the turning circle bigger and generally cost more. In the conditions I get off road here, I'd take a Defender on 7.50s over anything else short of a tractor. Personally I think they look better too, but that's quite a personal thing. |
14th May 2015 5:19pm |
rover Member Since: 26 May 2012 Location: Yorkshire Posts: 150 |
Completely agree,
There is nothing wrong with michelin lattitude cross tyres on standard 7.5 -16 wheels. I like the classic look, they behave good on the road and are a lot better offroad than most people think, in a lot of off road sitiuations narrow tyres are best. Going beyond 235 width is completely pointless unless you just like the fat tyre look. |
16th May 2015 3:38pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 741 |
Will 7.5-16 fit on 16x7 Boost alloys? I've come across a set of Latitude Cross tires in 7.5-16 but am not sure if they can be used with my Boost alloys. Currently running 235/85/R16 Federal Couragias that are getting tauntingly close to the TWI.
26th May 2015 5:47am |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 |
I'm currently on Grabber TRs on the front and Conti Cross AT on the rear... They seem ok on motorway at speed, I haven't got them muddy yet, but the tread pattern looks pretty capable.
I know mixing tyres is usually a bad idea, but they came with the truck and they look more or less brand new in terms of tread wear. Don't think I'll be spending hard earned changing them just yet as I have other mods I'd rather do first, although the front pair do seem to have something of a bulge to them. (I checked the pressures, up at 33psi as per manual) I shall watch this, and all the other tyre threads, with interest though... |
26th May 2015 8:01am |
