Home > Technical > Clonk clonk |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5663 |
Drive flange
Diff pinion flange Rear axle ball joint Wheel nuts Drive flange bolts. All worth checking Andy |
20th Jan 2015 10:31pm |
Velo-felo Member Since: 18 Sep 2014 Location: Forest of Dean Posts: 19 |
Drive flange sounds very likely as its that kind of clicky clonk... If that makes sense.
I see a lot advertised as upgrades from OE, any one have a recommendation of choice? Thanks , Steve |
8th Mar 2015 10:12pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
I did mine very recently and went for Bearmach OEM. http://www.defender2.net/forum/topic28138-105.html
They were a nice tight fit and so far very happy Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
8th Mar 2015 11:25pm |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 |
I changed my rear prop uj's at the weekend to cure a clonk I was getting on pulling away and lifting on/off he accelerator. When I tried to move the prop by hand I couldn't get any movement at all, it wasn't until I lay down beside the defender while the GF reversed/drove forward up and down the drive could I hear the prop moving.
Once I had stripped the rear prop off it was very obvious that was the problem and I am glad I did before the prop fell apart! |
9th Mar 2015 10:35pm |
