Home > Technical > Clonk clonk
Velo-felo
United Kingdom 2007 Defender 90 Puma 2.4 SW Keswick Green
Clonk clonk
I've noticed that I have a slight clonk noise which sounds to be n/s/r when pulling away.. Requires some gentle clutch and throttle work to avoid it.. Any obvious things to check? Can't see any loose suspension bolts or bushes... Uj's I think are ok.. It's a 2005 TD5, thanks...
Post #390801 20th Jan 2015 9:44pm
landy andy
Drive flange
Diff pinion flange
Rear axle ball joint
Wheel nuts
Drive flange bolts.
All worth checking
Andy
Post #390831 20th Jan 2015 10:31pm
Velo-felo
Drive flange sounds very likely as its that kind of clicky clonk... If that makes sense.
I see a lot advertised as upgrades from OE, any one have a recommendation of choice?
Thanks , Steve
Post #405816 8th Mar 2015 10:12pm
shaggydog
I did mine very recently and went for Bearmach OEM. http://www.defender2.net/forum/topic28138-105.html
They were a nice tight fit and so far very happy Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #405837 8th Mar 2015 11:25pm
Alex1976
I changed my rear prop uj's at the weekend to cure a clonk I was getting on pulling away and lifting on/off he accelerator. When I tried to move the prop by hand I couldn't get any movement at all, it wasn't until I lay down beside the defender while the GF reversed/drove forward up and down the drive could I hear the prop moving.
Once I had stripped the rear prop off it was very obvious that was the problem and I am glad I did before the prop fell apart!
Post #406153 9th Mar 2015 10:35pm
