Home > Technical > 2000 Td5 wiper relay location |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Did a search. The result of which is says that the relay is behind the instrument cluster.
http://www.defender2.net/forum/topic5276.h...cation+td5 Not on mine. (not sure if it has to do with being a LHD) Behind the cluster is the immobilizer control. The centre fuse block had about 20 fuses, 4 relays below, and 2 above. I'm guessing it's the red one above? Any body have any input? |
16th Jan 2015 4:04am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Yes, it's on the fuse box panel, red in colour if it's the original one. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
16th Jan 2015 10:09am |
Superb! Thanks guys!
18th Jan 2015 8:41pm |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 |
While on the topic - does anyone know if its possible to replace the relay with an intermittent wipe one? I don't need it running permanently, but a wipe ever few seconds would be beneficial.
20th Jan 2015 1:17pm |
The front wiper does have an intermittent setting already - push the stalk down! 1988 90 Td5 NAS soft top
2015 D90 XS SW |
20th Jan 2015 2:28pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
Not on pre tdi engined vehicles! 02' 110 TD5 Double Cab Rebuild Thread
20th Jan 2015 3:47pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
you need the MUD wiper mod!!!
http://www.mudstuff.co.uk/defender-programmable-wiper-relay.html |
20th Jan 2015 4:03pm |
Indeed - have one myself. But Hufflepuff has a Td5 (according to the icon) 1988 90 Td5 NAS soft top 2015 D90 XS SW |
20th Jan 2015 4:30pm |
Wont work on a vehicle which didnt originally have inermittant wipe! Also you could save yourself 30quid and get the vw 99. relay from ebay ir scrappy! 02' 110 TD5 Double Cab Rebuild Thread
20th Jan 2015 4:31pm |
Sorry lads - I meant the rear (can't believe I missed that off the comment).
20th Jan 2015 11:36pm |
21st Jan 2015 9:28am |
Awesome, thanks mk1collector!
21st Jan 2015 1:09pm |
Someone else's knowledge I just remembered the link
21st Jan 2015 3:26pm |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
I did this mod a couple of months ago. I found it from this thread;
http://www.defender2.net/forum/topic4625.h...rear+wiper It's been great. It was simple and easy to do. |
21st Jan 2015 3:36pm |
