Home > Technical > 2000 Td5 wiper relay location
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Did a search. The result of which is says that the relay is behind the instrument cluster.
http://www.defender2.net/forum/topic5276.h...cation+td5
Not on mine. (not sure if it has to do with being a LHD) Behind the cluster is the immobilizer control.
The centre fuse block had about 20 fuses, 4 relays below, and 2 above. I'm guessing it's the red one above?
Any body have any input?
Post #388925 16th Jan 2015 4:04am
Anderzander
On my 2000 Td5 it was in the bulkhead fuse panel.
I found it by removing the cover and turning the wipers on - I could hear and feel the relay click then.
You could also turn the wipers on and pull the relay to confirm it stops.
Post #388937 16th Jan 2015 8:12am
Martin
Site Admin
Yes, it's on the fuse box panel, red in colour if it's the original one.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #388967 16th Jan 2015 10:09am
CDN38
Superb! Thanks guys!
Post #389988 18th Jan 2015 8:41pm
Hufflepuff
While on the topic - does anyone know if its possible to replace the relay with an intermittent wipe one? I don't need it running permanently, but a wipe ever few seconds would be beneficial.
Post #390530 20th Jan 2015 1:17pm
Martin
Site Admin
The front wiper does have an intermittent setting already - push the stalk down!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #390548 20th Jan 2015 2:28pm
rallysteve
Not on pre tdi engined vehicles! 02' 110 TD5 Double Cab Rebuild Thread
Post #390579 20th Jan 2015 3:47pm
Post #390583 20th Jan 2015 4:03pm
Martin
Site Admin
Indeed - have one myself. But Hufflepuff has a Td5 (according to the icon)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #390591 20th Jan 2015 4:30pm
rallysteve
Wont work on a vehicle which didnt originally have inermittant wipe! Also you could save yourself 30quid and get the vw 99. relay from ebay ir scrappy! 02' 110 TD5 Double Cab Rebuild Thread
Post #390592 20th Jan 2015 4:31pm
Hufflepuff
Sorry lads - I meant the rear (can't believe I missed that off the comment).
Post #390848 20th Jan 2015 11:36pm
mk1collector
Post #390914 21st Jan 2015 9:28am
Hufflepuff
Awesome, thanks mk1collector!
Post #391030 21st Jan 2015 1:09pm
mk1collector
Someone else's knowledge Mr. Green I just remembered the link Thumbs Up
Post #391063 21st Jan 2015 3:26pm
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
I did this mod a couple of months ago. I found it from this thread;
http://www.defender2.net/forum/topic4625.h...rear+wiper
It's been great. It was simple and easy to do.
Thumbs Up
Post #391065 21st Jan 2015 3:36pm
