Home > Technical > Leaking sunroof
timtom1
United Kingdom 2001 Defender 90 Td5 CSW Alveston Red
Leaking sunroof
My sunroof is leaking as per usual, so I sealed it on the outside with sealant, but its still dripping through where the window hinges meet the metal and also collects in-between the rubbers. I thought about taking my headlining out this weekend for further investigation. Any other ideas how to stop it?
Thanks
Tim
 2001 90 TD5 CSW Alveston Red Manual
Post #388864 15th Jan 2015 9:22pm
ickle
If its between the frame and roof skin, only real way is to take it out, clean off all old sealer and reinstall with a decent mastic sealer and edge seal with silicone.
If its between glass and rubber, take out glass and thoroughly clean, wipe seal with meths then apply smear of Vaseline on seal and reassemble.
Good luck
Keith
Post #388870 15th Jan 2015 9:35pm
timtom1
thanks Keith I will give it ago.. I've also been advised on another forum Gorilla tape works if you cover the entire seal Exclamation Question Exclamation so I will have a bash this weekend I let you know how I get on.. Thumbs Up 2001 90 TD5 CSW Alveston Red Manual
Post #388882 15th Jan 2015 9:58pm
Waldo
I took the glass out, removed the rubber seal.
Then put sealant in the channel where the seal sits and replaced.
So far it's held up perfectly.
I also sealed the roof to sunroof.
Used sikaflex
Will Defender 90 XS TD5 (03 Reg)
Post #389215 16th Jan 2015 8:47pm
hornet
Re: Leaking sunroof
[quote="timtom1"]My sunroof is leaking as per usual, so I sealed it on the outside with sealant, but its still dripping through where the window hinges meet the metal and also collects in-between the rubbers. I thought about taking my headlining out this weekend for further investigation. Any other ideas how to stop it?
Thanks
Tim
[img:417:567]https://www.defender2.net/gallery/albums/userpics/13374/sunroof.jpg[/img][/quote]
If you understand a bit German, there exist a "Handbook for water leaks to defenders", find it here: http://www.landroverweb.com/Pdf-files/Manu...0Rover.pdf
Post #394065 30th Jan 2015 2:20pm
timtom1
thank you Smile I will use google translate Thumbs Up 2001 90 TD5 CSW Alveston Red Manual
Post #394227 30th Jan 2015 9:43pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Tim
Here's the link to a variety of manuals including water ingress Thumbs Up
http://www.landroverweb.com/landrover/pdf-...v8-petrol/
John 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #394235 30th Jan 2015 9:58pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Water Ingress Manual
Post #394280 31st Jan 2015 12:19am
jomara
^^^^ Rolling with laughter Rolling with laughter
And that's only volume 1 Shocked 2014 110 2.2TDCi XS Station wagon
Post #394298 31st Jan 2015 6:47am
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Tim
As an alternative to Vaseline (shouldn't be used on rubber products Whistle ) try using silicone grease available from all plumbers merchants. I have used it on my roof with great success.
Post #394337 31st Jan 2015 10:01am
countdecash
Ireland 1999 Defender 90 Td5 CSW Epsom Green
I know it's an old topic now but did you get sorted Timtom1? My 90 CSW has the same issue , leaking at the sunroof hinges.....it's pouring in.....
Post #703290 26th Apr 2018 11:51am
gilarion
Your wrong that's just the index Laughing For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #703332 26th Apr 2018 3:28pm
red zepplin
1998 Defender 90 300 Tdi HT Rioja Red
Hi I had the same issue with the roof on the zepplin i did have some success with ct1 but in the end I replaced the roof they all end up leaking eventually but ct1 is pretty good noticed your on lancashire too Tim I still have the old sunroof if you need parts but I can't vouch for their water tightness
Simon WHAT COULD POSSIBLY GO WRONG
My sky lantern petition
http://chng.it/HJXmZC47
Post #703336 26th Apr 2018 4:13pm
LinDens90XS
2003 Defender 90 Td5 XS CSW Bonatti Grey
Have had this problem also, after trying various ways, I eventually removed the sunroof altogether, stripped it down and gave it a good clean and reassembled with just a touch of sealant and it has been fine for about 5yrs now. Worth the effort in the end. Regards
Dennis.
Post #703681 27th Apr 2018 9:15pm
