Home > Technical > Leaking sunroof |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1780 |
If its between the frame and roof skin, only real way is to take it out, clean off all old sealer and reinstall with a decent mastic sealer and edge seal with silicone.
If its between glass and rubber, take out glass and thoroughly clean, wipe seal with meths then apply smear of Vaseline on seal and reassemble. Good luck Keith |
15th Jan 2015 9:35pm |
timtom1 Member Since: 10 Jul 2012 Location: Lancashire Posts: 148 |
thanks Keith I will give it ago.. I've also been advised on another forum Gorilla tape works if you cover the entire seal so I will have a bash this weekend I let you know how I get on.. 2001 90 TD5 CSW Alveston Red Manual
15th Jan 2015 9:58pm |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
I took the glass out, removed the rubber seal.
Then put sealant in the channel where the seal sits and replaced. So far it's held up perfectly. I also sealed the roof to sunroof. Used sikaflex Will Defender 90 XS TD5 (03 Reg) |
16th Jan 2015 8:47pm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 361 |
[quote="timtom1"]My sunroof is leaking as per usual, so I sealed it on the outside with sealant, but its still dripping through where the window hinges meet the metal and also collects in-between the rubbers. I thought about taking my headlining out this weekend for further investigation. Any other ideas how to stop it?
Thanks Tim [img:417:567]https://www.defender2.net/gallery/albums/userpics/13374/sunroof.jpg[/img][/quote] If you understand a bit German, there exist a "Handbook for water leaks to defenders", find it here: http://www.landroverweb.com/Pdf-files/Manu...0Rover.pdf |
30th Jan 2015 2:20pm |
thank you I will use google translate 2001 90 TD5 CSW Alveston Red Manual
30th Jan 2015 9:43pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Hi Tim
Here's the link to a variety of manuals including water ingress http://www.landroverweb.com/landrover/pdf-...v8-petrol/ Cheers John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
30th Jan 2015 9:58pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Water Ingress Manual
Click image to enlarge |
31st Jan 2015 12:19am |
And that's only volume 1 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
31st Jan 2015 6:47am |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1760 |
Tim
As an alternative to Vaseline (shouldn't be used on rubber products ) try using silicone grease available from all plumbers merchants. I have used it on my roof with great success. |
31st Jan 2015 10:01am |
countdecash Member Since: 14 Mar 2016 Location: dublin Posts: 24 |
I know it's an old topic now but did you get sorted Timtom1? My 90 CSW has the same issue , leaking at the sunroof hinges.....it's pouring in.....
26th Apr 2018 11:51am |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5110 |
Your wrong that's just the index For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
26th Apr 2018 3:28pm |
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 |
Hi I had the same issue with the roof on the zepplin i did have some success with ct1 but in the end I replaced the roof they all end up leaking eventually but ct1 is pretty good noticed your on lancashire too Tim I still have the old sunroof if you need parts but I can't vouch for their water tightness
Simon WHAT COULD POSSIBLY GO WRONG My sky lantern petition http://chng.it/HJXmZC47 |
26th Apr 2018 4:13pm |
LinDens90XS Member Since: 24 Feb 2012 Location: Merseyside Posts: 83 |
Have had this problem also, after trying various ways, I eventually removed the sunroof altogether, stripped it down and gave it a good clean and reassembled with just a touch of sealant and it has been fine for about 5yrs now. Worth the effort in the end. Regards
Dennis. |
27th Apr 2018 9:15pm |
