Home > In Car Electronics > Tow bar electrics - trailer light with no trailer
dashed
United Kingdom 2015 Defender 90 Puma 2.2 HT Stornoway Grey
Hi, just purchased a new Defender (after about 6 years of Discovery ownership) and have fitted an aftermarked towbar. I went for the dedicated electrics kit, with the socket on the end, so simply connected to the plug hidden behind the rear offside lights. I've not had a chance to connect it up to the trailer yet, but without the trailer connected the trailer indicator light on the dashboard flashes once every time I indicate. I've been told by the place I bought the kit that this is normal, but didn't do it in the demonstrator I borrowed from LR (with factory fitter towbar).
Is it normal and do I need to fork out the £160 for the LR wiring loom to avoid it doing this - it's a bit irritating!!
Post #387660 12th Jan 2015 11:33am
It is normal and correct that the trailer repeater flashes once (with the first flash of the indicators) if there is no trailer connected. If there is a trailer, it will continue to flash with the indicators.
Post #387663 12th Jan 2015 11:39am
JWL
If it just flashes once when you indicate then that's normal, it is doing a check to see if there's a trailer fitted or not. Just hope that it will keep flashing when there's a trailer attached Whistle
Post #387664 12th Jan 2015 11:40am
dashed
Many thanks for the super quick reply! is this the same with both after market and orginal LR?
Post #387665 12th Jan 2015 11:40am
grafty99
its a throw back from the times when dash warning lights were filament bulbs instead of led, its a bulb check Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #387667 12th Jan 2015 11:53am
Martin
Site Admin
Does it even with no electrics connected Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #387668 12th Jan 2015 11:54am
grafty99
my dads tdi 110 does it with factory kit, as did my td5 before I changed to leds and wipac trailer relay Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #387669 12th Jan 2015 11:56am
dashed
Thanks all! Have to admit I didn't notice it doing it without the electrics connected, but I've not driven a couple of hundred miles yet! Embarassed
Post #387670 12th Jan 2015 11:59am
It won't do it if you have an RDX relay, only if a trailer is connected.
Post #387682 12th Jan 2015 12:39pm
NOODLES25
My 90 does it with factory towbar,didn't realise why until now.
Post #388597 14th Jan 2015 10:28pm
