Home > Puma (Tdci) > 2.4 Intercooler Fitting - Hood Latch Panel Removal Problems
Page 2 of 2 <12
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Where did you get them? Or we're they made specifically for you, as I've only seen silicone ones advertised.
I'm thinking of cleaning out inlet manifold too as the egr has well and truly made a mess inside!
Every little helps!! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #387032 10th Jan 2015 2:19pm
K9F
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #387035 10th Jan 2015 2:25pm
ian series 1
Ooohhh! You went for the big one! Bow down 80" 80" 86" 88" 90"
Post #387059 10th Jan 2015 3:49pm
K9F
Tell me about it.... Laughing
Had a complete nightmare trying to get the silicone unions to fit due to limited access and non-flexibilty of the stainless pipes. Became a battle of wills between me and the unions. Perseverance prevailed in the end.
Post #387062 10th Jan 2015 3:57pm
SupraAyf
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
K9F wrote:
So much less complicated without airconditioning.
Too right sir. The only things to remove and adjust were the front cross struts (not shown in the pics) - but the thought of fitting a hard pipe kit to the FMIC would not be my idea of fun. It only took a few minutes for the silicone kit to be fitted but a hard pipe kit - that's a different ball game all together. You did well Smile - Andrew -
Post #387152 10th Jan 2015 7:13pm
SupraAyf
ian series 1 wrote:
I have noticed a slight drop in running temperature, my needle sat exactly half way before.
Now runs just slightly under.
When payday arrives I'm having an Alive re map then I am hoping the large square blingy thing will give me a return on the investment Whistle
I'm running on standard hoses at the moment too, is it worth the extra for the silicone hoses?
I suppose at the end of the day if you've spent that much may as we'll go the whole hog?
Ian, I picked up the hoses for £35 (delivered) as they were shop soiled. The original cost was £85 but no one in their right mind would pay that type of money for banana-yellow silicone.
Like you I now need a remap to help mate the new hybrid turbo with the right air-fuel mixture etc. The 5-ply silicone hoses will hopefully make for a much more rigid system which is less effected by pressure fluctuations. - Andrew -
Post #387159 10th Jan 2015 7:19pm
Page 2 of 2 <12
