Home > Puma (Tdci) > 2.4 Intercooler Fitting - Hood Latch Panel Removal Problems |
Click image to enlarge Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Jan 2015 3:25pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Ooohhh! You went for the big one! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
10th Jan 2015 4:49pm |
Tell me about it....
Had a complete nightmare trying to get the silicone unions to fit due to limited access and non-flexibilty of the stainless pipes. Became a battle of wills between me and the unions. Perseverance prevailed in the end. Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Jan 2015 4:57pm |
SupraAyf Member Since: 08 Sep 2014 Location: Durham Posts: 142 |
Too right sir. The only things to remove and adjust were the front cross struts (not shown in the pics) - but the thought of fitting a hard pipe kit to the FMIC would not be my idea of fun. It only took a few minutes for the silicone kit to be fitted but a hard pipe kit - that's a different ball game all together. You did well - Andrew - |
10th Jan 2015 8:13pm |
Ian, I picked up the hoses for £35 (delivered) as they were shop soiled. The original cost was £85 but no one in their right mind would pay that type of money for banana-yellow silicone. Like you I now need a remap to help mate the new hybrid turbo with the right air-fuel mixture etc. The 5-ply silicone hoses will hopefully make for a much more rigid system which is less effected by pressure fluctuations. - Andrew - |
10th Jan 2015 8:19pm |
