Home > In Car Electronics > Poor DAB and FM since DRL install :(
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Hi
Since I've installed some DRLs I have had interference with radio reception. Positive for the DRLs is direct from the battery but the negative is back to the bulkhead earth by the ECU.
I would a negative direct to the battery solve the problem or is there a in line suppressor that I can use to get rid of the interference?
Thanks 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #385529 6th Jan 2015 6:11pm
NigelM
I had terrible am reception when the headlights were on. Previous owner had installed HID's. The ballasts were bolted to the inside of the engine compartment - metal cased ballasts onto a metal bracket. I didn't move them, just insulated the ballasts from their bracket.
All reception issues instantly disappeared.
Post #385534 6th Jan 2015 6:20pm
carrotbay
Unfortunately I've got nothing to insulate here. Just 2 plastic DRL modules with a positive and negative. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #385600 6th Jan 2015 8:03pm
kmac
You can make an inline supressor
Have a look here
http://www.defender2.net/forum/topic26844....adio+choke
Post #386081 7th Jan 2015 7:54pm
jhnstap
United Kingdom 2005 Defender 90 Td5 XS CSW Tonga Green
Suppressors
I had similar when fitting the DLR form MobileCentre, went with Ferrite suppressors, seemed to help
http://www.ebay.co.uk/sch/i.html?_from=R40...p;_sacat=0 I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine
Post #386204 8th Jan 2015 6:55am
carrotbay
I fitted an inline suppressor on the ignition feed to the head unit. This has had no effect. Should it have been to the constant positive to the head unit instead or as well ? 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #389207 16th Jan 2015 8:35pm
kmac
You have to fit the suppressor to the item causing the "noise" not to the stereo
In this case fit to the DRLs
Post #389249 16th Jan 2015 9:56pm
