Home > Maintenance & Modifications > Front door stays
Front door stays
On mine on door the drivers side will stay open on the door stay most of the time but not the other on the passenger side.
Even a slight slope will make a difference too, nearly all other cars the door will stay open at a point on the support stay.
I'm guessing it's the pin loose but never been able to fathom exactly what needs tightening to sort it, if of course you can. Confused
It's a massive pain when your trying to do work on it and if you inside you've got the door leaning against you or the wind pushing it about.
Other than that you have to keep opening it time after time and it really gets annoying. Mad
Post #385048 4th Jan 2015 11:07pm
There's a spring arrangement on the bulkhead which engages in a detent on the inboard end of the stay arm. Trouble is the dash has to come out (or at least be released and pulled away from the bulkhead) to get at them.
I usually tie a rope from the outside door handle to the front bumper or similar when working on uneven ground or in wind.
Post #385050 4th Jan 2015 11:15pm
spudfan
Ireland
Not the easiest thing to access. Look under the dash where the stay disappears into. You can tighten it up inside there, but it is a b***h to access. There is a visible nut head and one under the trim across from that. These slacken, the outside visible one is easily done but it's the hidden one that is the awkward one. Get done on your knees and pull the plastic out with your fingers, look up and you'll see the second nut. A suitably bent spanner of the correct size is needed to access it. Enjoy Very Happy Could you post a follow up and let us know how many swear words you use getting it done? Mr. Green 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #385053 4th Jan 2015 11:25pm
Me swear. Rolling with laughter Whistle
In all honesty I haven't tried to tighten it bar having a quick look.
Obviously having a look and realising it would be a devil to get at put me off this long. Laughing
Post #385057 4th Jan 2015 11:50pm
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
Does anyone know where I could buy this part from please, my drivers door opens to wide because the bump stop is missing.
The bracket with the vertical bar attached to it.
Failing that I might have to repair it
 2005 TD5 90 CSW XS
Post #385090 5th Jan 2015 9:16am
munch90
I had the bolts come loose ( the two in the pic above ) , tightening them fixed the door not staying open
Post #385112 5th Jan 2015 10:29am
Kent_keith
Ok thank you I'll have a look, Thumbs Up when I compared one side to the other, I thought I saw what I thought was a bump stop or something stopping the door travelling too far past the vertical bar? I'll have a poke around Very Happy 2005 TD5 90 CSW XS
Post #385114 5th Jan 2015 11:03am
spudfan
Ireland
The above photo gives an excellent view of the two nuts that need tightened. This will get the door stay back in action. 1982 88" 2.25 diesel
Post #385124 5th Jan 2015 12:32pm
Green Machine
Very useful having Keith's pic to refer to, as it's very difficult to describe in words! But on mine the passenger door wouldn't stay open either, so did some investigating. It's easier to get at on a Td5 (just has its own little plastic cover held on with a single screw). Anyway, I found that the bent 's' shaped bar that acts as a spring was too long and the bottom edge of it was fouling on the sliding track, stopping it from dropping into the notch when the door was open. So i just chopped a bit off the end of it and I also 'flattened' it slightly in a vice to give it more spring effect. Reinstalled and the door stays open perfectly now. It was one of my most triumphant Land Rover bodging moments! Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #385136 5th Jan 2015 1:37pm
Kent_keith
Is there a notch in the roller? That would make sense, although mine is travelling past the retention/spring bar and all the to the end so opens too far, but it may be the same problem Thumbs Up 2005 TD5 90 CSW XS
Post #385138 5th Jan 2015 1:48pm
spudfan
Ireland
Yep everything depends on how your nuts are adjusted (the one's on the Land Rover I mean Whistle ) 1982 88" 2.25 diesel
Post #385139 5th Jan 2015 2:06pm
driver9
Thanks chaps another task ticked off the list of things to sort out. As have found the bolts were loose but easy to tighten on a Puma providing you use a suitably cranked spanner and remove a couple of the dash mounting screws.
Post #385150 5th Jan 2015 3:28pm
mk1collector
Mine seem to come loose every couple of years so put some thread lock on if you want it to stay put Thumbs Up
Post #385175 5th Jan 2015 5:22pm
Kent_keith
Good idea, I'll look into that next Saturday as I'm too much of a wimp to go out there now because it's dark and cold Embarassed Very Happy 2005 TD5 90 CSW XS
Post #385179 5th Jan 2015 5:41pm
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Yours does seem to be missing the bump stop as the roller should not be able to move much beyond the position your first photo shows. Part number is MWC5759. A chunk of thick rubber the correct size will be equally effective.
Post #385227 5th Jan 2015 7:10pm
