Home > Maintenance & Modifications > RDX led light sets Any good?
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Hi guys has anybody got the RDX clear led light sets are they any good, I know the fog light has a slightly different look but any other issues?
Cheers for feedback Very Happy
Post #384835 4th Jan 2015 3:51pm
I have them, at least clear on the front and colours on the rear.
No complaints what so ever. Thumbs Up
Post #384837 4th Jan 2015 3:53pm
Phatcat
United Kingdom 2002 Defender 90 Td5 CSW Java Black
I have them, clear all round. Had them on 8 months, no issues yet.
Post #384866 4th Jan 2015 5:06pm
munch90
all good here
my advise would be buy rdx small lights (stop/tail ,indicators, front sides ) but buy rev and fog in wipac then you get a matching pair
Post #384868 4th Jan 2015 5:17pm
Oakseywick
Thanks guys glad there is no issues as they look god for the money I will get some next week. Have either of you good there nas guards that they do for them aswell? Thumbs Up
Post #384869 4th Jan 2015 5:18pm
Alex1976
I have had a full set of these on for over 2 years now and they are top notch. Would recommend them without hesitation.
Post #384870 4th Jan 2015 5:19pm
HardCharger
How different are the RDX LEDs compared to the Wipac LEDs?
When munch90 suggested to get the fog and rev lights from Wipac, I'm guessing the Wipac ones will just be plug and play rather than having to cut up wire?
Does Wipac make LED license plate lights too?
If Wipac is more plug and play, are their output better than stock? How do they compare to RDX?
Also, I where can one get all the Wipac lights in one go if this is the way to go? Most sites only have the marker, signal, and brake lights as sets. RDX has them all though.
Input and thoughts welcome as I'm considering this as a potential upgrade as funds become available.
Thanks!
Post #385062 5th Jan 2015 5:11am
ericvv
Post #385063 5th Jan 2015 5:29am
munch90
Thanks!
just get the econoseal plugs to fit on the wipac lamp
or buy then with them fitted already
wipac make the better number plate lamp
buying wipac just means you get matching reflectors on rev and fog , as in some of the sets you get a odd pair of reflectors , ok not the end of the world but if your spending your money you may as well have a matching set
ONLY thing is you cant get wipac fog in clear lens only red
Post #385082 5th Jan 2015 8:43am
Kitoper
Switzerland
I have the RDX led lights albeit the colour lights with the exception of the reverse light which is clear. I am more than happy with the quality and reliability of the set. I am not sure about WIPAC but RDX includeds the relay with their light package. The relay manages the indicators and can accomodate the trailer connection.
Post #385083 5th Jan 2015 8:43am
munch90
I fitted the whole rdx set without the flasher relay (didn't like flash rate )
then decided to fit extra rev and fog, then found I couldn't get fog or rev to match what I had , so in the end for wipac to get 2 matching fogs and 2 matching revs
Post #385085 5th Jan 2015 8:54am
Kitoper
Switzerland
Hello Munch,
The relay allows you to adjust the flash rate. The flash rate on mine matches OEM.
Post #385092 5th Jan 2015 9:33am
munch90
when I adjusted it right for the dash trailer light to work , it didn't look right also the dash trailer light don't work if you got led trailer lights fitted which I have on 2 of my trailers
I went back to a relay I already had that does either filament or led or mixed and fitted a buzzer as that works with any trailer light
the rdx flasher relay was within regulation flash rate but just looked slow compared to what I had been used to with my old led flasher relay just being fussy really , I already had another led relay because I went from just led bulbs to proper complete lamps
Post #385100 5th Jan 2015 9:49am
Kitoper
Switzerland
Interesting point about the RDX not being able to handle led lights on a trailer. I have not tried that yet as current trailers, only have filament bulbs. I would be interested in your relay for future. Thanks for the heads-up.
Happy New Year
Post #385105 5th Jan 2015 10:00am
munch90
it can handle led trailer load without problem and flashes led trailer light no problem , its the dash indicator lamp that doesn't work ( does say so in bolt on bits ebay listing for the relay )
I got 2 trailers on led and 2 trailers on filament bulbs , so needed something to cover both so now I don't bother with dash lamp and have a buzzer which I prefer as you need to look at the dash
Post #385111 5th Jan 2015 10:23am
