Home > Tdi > connecting discovery rear brake calipers!
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Can somebody tell me which type of flare I should be using, when I make the new brake pipes for my 90.
Land rover Discovery 300TDI axle.
Post #384187 2nd Jan 2015 4:29pm
munch90
sure there a single flare , so pointed looking on the end , or convex
if talking where the metal pipe goes into the caliper
just check by looking in the hole on the caliper to see if the bottom seating is pointing up or down
up = double
down = single
pretty sure all calipers ive seen use a single flare
Post #384196 2nd Jan 2015 4:59pm
steventheplumber
Thankyou very much for the speed reply.
Post #384201 2nd Jan 2015 5:12pm
jst
i have given up with the normal pipes now on rebuilds and tend to get custom made stainless flexi ones with a 45 or 90 deg bango straight to the caliper. more protection for the pipe plus does away with the need of the small copper pipe on the front (mtd to kingpin bracket) so you can go direct chassis mount to caliper Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #384274 2nd Jan 2015 7:40pm
steventheplumber
Thats a thought, pictures would be helpful.
Post #384306 2nd Jan 2015 8:43pm
munch90
Fitting banjo bolt type fitting is ok if the surface around the threaded hole is machined flat and smooth and parallel to the hole and made to have that style of fitting
calipers that are made to have a banjo fitting used have lugs to support the crimped part because a if banjo fitting gets knocked round it can undo the bolt and start leaking
Changing the style of fittings is not something i would do or recommend !
Post #384317 2nd Jan 2015 9:21pm
jst
i have done it on 3 of my vehicles now, two of them compete in winch challenge regularly. no failure to date. the copper washers take out any small imperfections. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #384599 3rd Jan 2015 7:25pm
jst
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #384601 3rd Jan 2015 7:28pm
steventheplumber
Thats very smart James, proper job
Post #384725 4th Jan 2015 8:58am
