![]() | Home > Tdi > connecting discovery rear brake calipers! |
sure there a single flare , so pointed looking on the end , or convex
if talking where the metal pipe goes into the caliper just check by looking in the hole on the caliper to see if the bottom seating is pointing up or down up = double down = single pretty sure all calipers ive seen use a single flare |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
Thankyou very much for the speed reply.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8172 ![]() ![]() ![]() |
i have given up with the normal pipes now on rebuilds and tend to get custom made stainless flexi ones with a 45 or 90 deg bango straight to the caliper. more protection for the pipe plus does away with the need of the small copper pipe on the front (mtd to kingpin bracket) so you can go direct chassis mount to caliper Cheers
Thats a thought, pictures would be helpful.
Fitting banjo bolt type fitting is ok if the surface around the threaded hole is machined flat and smooth and parallel to the hole and made to have that style of fitting
calipers that are made to have a banjo fitting used have lugs to support the crimped part because a if banjo fitting gets knocked round it can undo the bolt and start leaking Changing the style of fittings is not something i would do or recommend ! |
i have done it on 3 of my vehicles now, two of them compete in winch challenge regularly. no failure to date. the copper washers take out any small imperfections. Cheers
![]() James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thats very smart James, proper job
