Home > Puma (Tdci) > adjusting steering wheel |
dazzx10r Member Since: 26 Nov 2014 Location: Rotherham Posts: 17 |
My 2 week old Defender is the same, straight from the production line! I think Land Rover may need to invest in new alignment equipment.
12th Dec 2014 5:48pm |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
You need to adjust the drag link from the steering box, this will alter the angle of the steering wheel in relation to the wheel position without altering any tracking settings. It won't need more than about half a turn I'd have thought.
Start by centring the steering wheel in the straight ahead position, there is space for a dowel pin to locate the drop arm if you want to be really precise. I started with nothing and still have most of it left! |
12th Dec 2014 6:46pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Mine's just the same.
(Should we move this to the 'Grumpy old men' thread?) |
12th Dec 2014 6:49pm |
Zouritte Member Since: 29 Jan 2014 Location: Ain Posts: 69 |
thank you, i'll have a look at that tomorrow
12th Dec 2014 7:13pm |
V12vanquish Member Since: 28 Sep 2014 Location: Northern Ireland Posts: 52 |
Mine was delivered new exactly the same. See my earlier post, it's an easy fix on the drag link adjustment.
12th Dec 2014 8:56pm |
V12Vanquish can't find your latest post about it, would you have a link?
T |
12th Dec 2014 10:20pm |
It was indeed an easy fix, just needed a little brute force and WD-40 and the bar was free.. done the adjustment with about half a turn, well done Rickydodah.
Thank you guys... it's much better now. Tim |
13th Dec 2014 3:10pm |
