Home > Puma (Tdci) > adjusting steering wheel
Zouritte
France 2010 Defender 110 Puma 2.4 SW Java Black
Hi everyone,
i have a TD4 / 48 splines steering wheel and when driving straight the steering wheel is slightly turned to the left, if i change the steering wheel position of one spline to the right, it goes slightly to the right when driving straight Big Cry
Do you guys have a solution on how to fix this? an adjustment on the rod? or anywhere else?
Thanks
Tim
Post #378453 12th Dec 2014 5:46pm
dazzx10r
My 2 week old Defender is the same, straight from the production line! I think Land Rover may need to invest in new alignment equipment. Laughing
Post #378455 12th Dec 2014 5:48pm
Rickydodah
You need to adjust the drag link from the steering box, this will alter the angle of the steering wheel in relation to the wheel position without altering any tracking settings. It won't need more than about half a turn I'd have thought.
Start by centring the steering wheel in the straight ahead position, there is space for a dowel pin to locate the drop arm if you want to be really precise.Thumbs Up I started with nothing and still have most of it left!
Post #378480 12th Dec 2014 6:46pm
Laurie
Mine's just the same.
(Should we move this to the 'Grumpy old men' thread?)
Post #378481 12th Dec 2014 6:49pm
Zouritte
thank you, i'll have a look at that tomorrow Smile
Post #378494 12th Dec 2014 7:13pm
V12vanquish
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Mine was delivered new exactly the same. See my earlier post, it's an easy fix on the drag link adjustment.
Post #378526 12th Dec 2014 8:56pm
Zouritte
V12Vanquish can't find your latest post about it, would you have a link?
T
Post #378554 12th Dec 2014 10:20pm
Zouritte
It was indeed an easy fix, just needed a little brute force and WD-40 and the bar was free.. done the adjustment with about half a turn, well done Rickydodah.
Thank you guys... it's much better now.
Tim
Post #378655 13th Dec 2014 3:10pm
