Home > In Car Electronics > Simple route sound improvement? |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Nothing too bad about my current [Standard] ICE set up ... but looking to improve the sound quality a tad without fitting bigger speakers, sub, etc,etc.. So ....
Are there 10 cm speakers out there that will give a much improved sound quality over the standard fit, But still using the LR radio? Could do with a bit more bass, and a less high tinny'ish sound. Are there better tweeters to fit top of dash, or is it better to just disconnect those? [They sound worse of all!] I know Steve loves his Kenwoods, and many others rate Focals ... But just as a 'speaker only' upgrade, which gives the best all round sound? Guns and Landrovers .... anything else is irrelevant. |
12th Dec 2014 1:30pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
In my opinion, the best 'simple' upgrade is a powered sub fitted to the rear of the cubby box.
I know it's not as easy as simply changing the existing speakers (and you said without fitting a sub) but 'bang for buck' it'll give you the most improvement |
12th Dec 2014 1:54pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 700 |
I wanted to do the same without too much faff.
I did however end up with one of these (Kenwood KSC-SW11) mounted on the back of the cubby box (http://www.ebay.co.uk/itm/KENWOOD-KSC-SW11...0779678168) I also replaced my rear speakers with some Focal PC100s. Still haven't done the fronts as sound now is pretty good. When I get round to it they will be replaced with Focal KRS100s. It was the sub that made all the difference and I only did the rears as one of them was playing up. 2008 Defender 110 XS SW - M57N2 / 6HP28X |
12th Dec 2014 2:53pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6612 |
Question is, Kenwood or Alpine sub? Kenwood is about £35 cheaper - it's a bit less than your link here: http://www.amazon.co.uk/Kenwood-KSC-SW11-U...B00BO8O9XQ 1988 90 Td5 NAS soft top
2015 D90 XS SW |
12th Dec 2014 3:21pm |
I've got no experience of the Alpine sub. The kenwood one was recommended from another forum user and I've been really impressed with it. 2008 Defender 110 XS SW - M57N2 / 6HP28X
12th Dec 2014 3:24pm |
Here's a link to a Kenwood Sub install .. http://www.defender2.net/forum/topic24922.html 2008 Defender 110 XS SW - M57N2 / 6HP28X
12th Dec 2014 3:25pm |
There have been lots of recommendations of the Alpine too, the Kenwood appears to have an inbuilt amp though, so a neater install. Hmmmmm 1988 90 Td5 NAS soft top
2015 D90 XS SW |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20479 |
You know which to choose Martin.
12th Dec 2014 3:27pm |
Buzz off you 1988 90 Td5 NAS soft top
2015 D90 XS SW |
12th Dec 2014 3:28pm |
Oooo and Merry Christmas to you too!
As others have mentioned a sub even a small active one will give you more improvement over just a speaker change. The speaker change is a close runner up though, from changing tweeers all you'll get is better high tones and clarity. |
12th Dec 2014 3:40pm |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 |
Pioneer make active sub's too. This one is an interesting new technology. http://www.carsoundsandsecurity.co.uk/store/ts-wh500a/ http://defender90xs.blogspot.co.uk/ |
12th Dec 2014 4:32pm |
LRmud Member Since: 22 Oct 2014 Location: IV12 Highland Posts: 198 |
To answer the OP's question, i should think any decent 4" speakers from a quality manufacturer would do the job perfectly. Just a question of budget - buy the best you can afford.
12th Dec 2014 5:06pm |
We definitely are not going sub route .. It's speaker upgrade only... Already got far too many 'additional' wiring looms
So more recommendations please guys ....... Guns and Landrovers .... anything else is irrelevant. |
12th Dec 2014 8:57pm |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 |
Got to be honest, the sound from the stereo today when I played it for the 1st time was pants!
12th Dec 2014 9:07pm |
