![]() | Home > In Car Electronics > Simple route sound improvement? |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Nothing too bad about my current [Standard] ICE set up ... but looking to improve the sound quality a tad without fitting bigger speakers, sub, etc,etc.. So ....
Are there 10 cm speakers out there that will give a much improved sound quality over the standard fit, But still using the LR radio? Could do with a bit more bass, and a less high tinny'ish sound. Are there better tweeters to fit top of dash, or is it better to just disconnect those? [They sound worse of all!] I know Steve loves his Kenwoods, and many others rate Focals ![]() |
In my opinion, the best 'simple' upgrade is a powered sub fitted to the rear of the cubby box.
I know it's not as easy as simply changing the existing speakers (and you said without fitting a sub) but 'bang for buck' it'll give you the most improvement |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
I wanted to do the same without too much faff.
I did however end up with one of these (Kenwood KSC-SW11) mounted on the back of the cubby box (http://www.ebay.co.uk/itm/KENWOOD-KSC-SW11...0779678168) I also replaced my rear speakers with some Focal PC100s. Still haven't done the fronts as sound now is pretty good. When I get round to it they will be replaced with Focal KRS100s. It was the sub that made all the difference and I only did the rears as one of them was playing up. 2008 Defender 110 XS SW - M57N2 / 6HP28X |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6644 ![]() ![]() ![]() |
Question is, Kenwood or Alpine sub? Kenwood is about £35 cheaper - it's a bit less than your link here: http://www.amazon.co.uk/Kenwood-KSC-SW11-U...B00BO8O9XQ
I've got no experience of the Alpine sub. The kenwood one was recommended from another forum user and I've been really impressed with it. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Here's a link to a Kenwood Sub install .. http://www.defender2.net/forum/topic24922.html 2008 Defender 110 XS SW - M57N2 / 6HP28X
There have been lots of recommendations of the Alpine too, the Kenwood appears to have an inbuilt amp though, so a neater install. Hmmmmm
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20652 ![]() ![]() |
You know which to choose Martin.
Buzz off you
Oooo and Merry Christmas to you too!
![]() ![]() As others have mentioned a sub even a small active one will give you more improvement over just a speaker change. The speaker change is a close runner up though, from changing tweeers all you'll get is better high tones and clarity. |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
Pioneer make active sub's too. This one is an interesting new technology. http://www.carsoundsandsecurity.co.uk/store/ts-wh500a/ http://defender90xs.blogspot.co.uk/ |
LRmud Member Since: 22 Oct 2014 Location: IV12 Highland Posts: 198 ![]() ![]() ![]() |
To answer the OP's question, i should think any decent 4" speakers from a quality manufacturer would do the job perfectly. Just a question of budget - buy the best you can afford.
We definitely are not going sub route .. It's speaker upgrade only... Already got far too many 'additional' wiring looms
![]() So more recommendations please guys ....... Guns and Landrovers .... anything else is irrelevant. |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 ![]() ![]() |
Got to be honest, the sound from the stereo today when I played it for the 1st time was pants!
