Home > Td5 > Tow Bar Wireing
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Tow Bar Wireing
Just a quick question, is there a plug in for towbar wireing in the TD5 rear harness or do I have to go through the drama's of patching into all the lights etc. Big Cry
Allan
Post #32825 24th May 2010 7:19am
dgardel
Italy
Near the Diesel filling tube (from cap to the tank) there is a plastic plate for rear lamps protection.
remove it (two screws).
there is a free 9 way connector, C0929 on Electric library (Sumitomo DL Series); this is the tow bar connector for plug in the harness to the trailer connector (named C1260 on the tow bar harness not on the car)........
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32831 24th May 2010 10:18am
Allan
Thanks heaps for that is that the same for puma and TD5
Allan
Post #32833 24th May 2010 10:36am
Yes 'tis
Post #32858 24th May 2010 4:41pm
Allan
Thank you
Allan
Post #32891 24th May 2010 10:46pm
MartinK
Has anyone found a source for the plastic plug (i.e. the male) which fits into the connector on the vehicl's wiring harness?
Apparently (done digging) we need a:
Quote:
Sumitomo DL Sealed Series - 090/187(2.3/4.8mm) – HYBRID, 9-Way Male Housing, Part No. M(6195-0173)
...but no-one seems to have found a source for them?
Hacked off that i could have taken the old one off my Discovery 2 - apparently they're the same Evil or Very Mad
I have a (unused) tow wiring kit in the garage, but I'll only use it is I can connect it without splicing the Defender's loom... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #90355 21st Sep 2011 12:39pm
When I looked into getting the compatible plug not long ago it was to all intents impossible in practical terms. You are better off using a pre-manufactured towing harness kit, they are not expensive (unless bought from a main dealer).
Post #90369 21st Sep 2011 1:20pm
PaulMc
I've tried, without success Sad , to track down a source for small quantities of the male and female connector shells, terminals, wire seals and blanking plugs.
I've found a few trade suppliers who'll supply them in quantities of several hundreds for the connector shells and several thousands for the terminals and seals and, even in those sort of quantities, the unit price is still very high Shocked
As BlackWolf has said, it's easier to fit a pre-made towing harness...
...and I just happen to have a Puma Defender 12N Kit (LR005920) up on eBay ATM Wink
http://www.ebay.co.uk/itm/200654026093
The main connector is the same as the TD5, but the additional connectors are now sealed connectors instead of bullets.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #90495 21st Sep 2011 8:51pm
MartinK
Rolling with laughter Paul - I am already bidding on that harness!
I was hoping to wire-up my car using the rubbish universal kit I have just as a temporary measure so I can use my trailer on Saturday (and your auction doesn't end till after the weekend) Rolling Eyes .
Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #90554 22nd Sep 2011 9:54am
PaulMc
Martin,
Good luck Thumbs Up
I've PM'ed you Smile
. Paul.
Post #90561 22nd Sep 2011 11:19am
JSG
I might have a harness in the garage - I'm sure it came off my 07 along with the tow bar when I sold it. John
2011 Tdci 110 CSW XS
Post #90574 22nd Sep 2011 12:20pm
AlexSmith
Brazil 2004 Defender 110 300 Tdi SW Alpine White
Quote:
Sumitomo DL Sealed Series - 090/187(2.3/4.8mm) � HYBRID, 9-Way Male Housing, Part No. M(6195-0173)
I was looking for the same thing and would assemble the connector myself, but - up to now - no luck.
I found this post, which supports what you said and adds a bit of info: https://forums.lr4x4.com/topic/62535-tow-b...ent-541955
Below is the text (and images) from that post, in case it goes offline...
The connector on the vehicle loom is a -
Sumitomo DL Sealed Series - 090/187(2.3/4.8mm) – HYBRID, 9-Way Female Housing, Part No. F(6195-0170)
The mating half you're looking for is a -
You will also need 7 x 090(2.3mm) and 2 x 187(4.8mm) Male Terminals, with the appropriate Wire Seals for each Terminal (I have the Part No's if you want them )
I haven't found anywhere selling the connector shells or the 187(4.8mm) terminals in sensible quantities, only the 090(2.3mm) terminals.
1. You could do as suggested in the post above - use individual 2.3mm and 4.8mm male terminals pushed into the connector terminals but, IMHO, that's a bit of a bodge
2. You could change the connector for a more readily available version of the Sumitomo DL Sealed Series connector -
http://www.easternbeaver.com/Main/Elec__Pr.../smdl.html
10-Way Sumitomo DL Sealed Series 090 Connector, Female and Male -
This would enable you to just transfer the 7 x 090 terminals on the vehicle loom to the new connector shell and, because you would be down-sizing the Aux. Live and Earth (pins 6 and 9), double-up the earth connection and down-rate the fuse on the Aux. Live.
3. You could just buy the Land Rover 12N Kit STC50081
Which plugs straight in, with no fuss.
​ 2020: Defender 110 SW 300 Tdi 2004 Alpine White
2013-2017: Defender 110 S 2.4 (Puma) 2008 Stornoway Gray
2002-2005: Defender 90 CSW 300 Tdi Dark Green
Post #966670 4th Oct 2022 5:10pm
rallysteve
I have removed the one from my TD5 and replaced with a Deutsch connector instead.
I have the male and female connector shells spare if anyone wants them?
Post #966683 4th Oct 2022 6:30pm
lightning
The harness has all connections except for the switched live.
lt has the permanent live, so your caravan ATC (if fitted) will work while you are towing but the fridge won't unless you add the switched live feed with a separate wire.
Post #966835 6th Oct 2022 7:32am
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Evening,
Has anyone ever de-pinned these plugs?
Thanks
Andy Working towards Carry on camping!
Post #1038985 2nd Jul 2024 7:26pm
