Home > Maintenance & Modifications > Reversing Camera
wolster
2000 Defender 110 Td5 USW Alpine White
Reversing Camera
Hello!
I've just popped over from the Disco 3 forum because for once its my Defender thats got me stumped.
I'm fitting a reversing camera so I can see whats going on at the towball when I back up to large trailers. All is fitted with camera on rear crossmember and cheapo Halfords DVD palyer in dash. I need to get a feed to the DVD player from the reversing light which will switch the camera on when reverse is selected. I can obviously run a wire from the rear light alongside the camera cable but its just another length of wire to mess with and go wrong. There must be something I can get to closer to the dash?? Does a reverse light feed pass through the fuse panel beneath the dash or perhaps under drivers seat?
Any help gratefully received.
Post #2153 21st May 2008 7:16am
B19DEF
The reverse light switch is on the side of the gearbox, you should be able to use this, rather than going straight to the reverse light.
Post #2154 21st May 2008 6:47pm
wolster
Thanks B19. Does it enter the cab at any point or just romp off rearwards towards the reversing light?
Post #2155 21st May 2008 8:41pm
sib
very interested to see how you get on as this is a mod I will certainly be trying on my new 130. pictures would be great if poss... Sib
Bath UK
1952 80 inch
1973 88 inch
2018 Morgan plus 4 narrow body
Post #2168 25th May 2008 7:07pm
wolster
Will do pics once all sorted. Don't hold your breath for that though!?!
Some pics will be in July issue of LRM mag!!!!
Post #2177 26th May 2008 6:53pm
diffbeer
Post #4775 18th Nov 2008 1:52pm
