Home > Maintenance & Modifications > Reversing Camera |
wolster Member Since: 21 May 2008 Location: Leicestershire Posts: 3 |
Hello!
I've just popped over from the Disco 3 forum because for once its my Defender thats got me stumped. I'm fitting a reversing camera so I can see whats going on at the towball when I back up to large trailers. All is fitted with camera on rear crossmember and cheapo Halfords DVD palyer in dash. I need to get a feed to the DVD player from the reversing light which will switch the camera on when reverse is selected. I can obviously run a wire from the rear light alongside the camera cable but its just another length of wire to mess with and go wrong. There must be something I can get to closer to the dash?? Does a reverse light feed pass through the fuse panel beneath the dash or perhaps under drivers seat? Any help gratefully received. |
21st May 2008 6:16am |
Thanks B19. Does it enter the cab at any point or just romp off rearwards towards the reversing light?
21st May 2008 7:41pm |
sib Member Since: 18 May 2007 Location: Baaath Posts: 144 |
very interested to see how you get on as this is a mod I will certainly be trying on my new 130. pictures would be great if poss... Sib
Bath UK 1952 80 inch 1973 88 inch 2018 Morgan plus 4 narrow body |
25th May 2008 6:07pm |
Will do pics once all sorted. Don't hold your breath for that though!?!
Some pics will be in July issue of LRM mag!!!! |
26th May 2008 5:53pm |
diffbeer Member Since: 18 Nov 2008 Location: Farnborough Posts: 44 |
18th Nov 2008 12:52pm |
