Home > 130 > Suspension question
Juddy
Australia 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Suspension question
As standard what suspension would my 130 run, ie spring and shock load rating, are the a. Medium load set up.
Since taking of the hcpu body that was maybe 130kg, and adding the quadtech that's around 450 at least, it's now siting a little lower on the tyres even with 60psi in, I would like to level it up a little, terrafirma sell a hd spring two inch lift and a hd spring standard ride hide, I will be fitting a 50 kg rack and a 12kg awning, and running most of the time like this, inside will have the spare and a 60ltr fridge and side lockers on the opening doors, from time to time a 60kg roof tent will also be fitted, what spring would you recommend.
Justin 2010 Defender 130 HCPU
1991 110 RFSV PERENTIE
www.landybitz.com.au
Post #373213 21st Nov 2014 9:01am
AndrewS
The standard UK springs are:-
Rear Brown and Purple both sides with smaller dia helper springs inside.
Front Drivers side Red and Blue
Front Passenger side Yellow and White.
Post #373489 22nd Nov 2014 3:40pm
Juddy
All sorted just fitted hd standard height and hd shocks, perfect. 2010 Defender 130 HCPU
Post #379605 17th Dec 2014 9:12am
