![]() | Home > 130 > Suspension question |
Juddy Member Since: 09 May 2013 Location: Queensland Posts: 63 ![]() ![]() ![]() |
As standard what suspension would my 130 run, ie spring and shock load rating, are the a. Medium load set up.
Since taking of the hcpu body that was maybe 130kg, and adding the quadtech that's around 450 at least, it's now siting a little lower on the tyres even with 60psi in, I would like to level it up a little, terrafirma sell a hd spring two inch lift and a hd spring standard ride hide, I will be fitting a 50 kg rack and a 12kg awning, and running most of the time like this, inside will have the spare and a 60ltr fridge and side lockers on the opening doors, from time to time a 60kg roof tent will also be fitted, what spring would you recommend. Cheers Justin 2010 Defender 130 HCPU 1991 110 RFSV PERENTIE www.landybitz.com.au |
All sorted just fitted hd standard height and hd shocks, perfect. 2010 Defender 130 HCPU
