Home > Td5 > Gearbox removal
excossack
Gearbox removal
What needs removing from inside the 110 to remove the gearbox/transfer case?
So far, Mud stuff tray, along with cubby box, carpet, maybe the transmission tunnel floor? (which I think is screwed in place?)
Or by putting the 110 on ramps, can you drop the TC and g/box in one via the use of a transmission jack ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #373137 20th Nov 2014 8:41pm
Assuming the Td5 is similar to the TDCi, the box must come out downwards. You'll need to remove the panel on the seat box between the front seats, and the centre tunnel of the floor. The crossmember under the box has to come off of course.
You can drop the unit easily on a transmission jack but it is often easier to remove the transfer box first, then the main box (definitely worth it on the Puma since it allows the notorious splined shaft to be inspected).
Post #373176 20th Nov 2014 10:36pm
landy andy
If you have ramp and g box jack, it can all be done from underneath and in one unit. But is easier if you get access from above and splitting the boxes makes it much lighter. If you are just doing clutch, then leave boxes together and just move them back out the way.
Post #373182 20th Nov 2014 11:05pm
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
Don't forget to remove the starter motor also, this is one of the most awkward parts as one nut is difficult to get to!
Have had gear box out twice ( along story) and did it with engine crane on my driveway. This method does require the removal of the floor though
Good luck with the job Thumbs Up
Post #373183 20th Nov 2014 11:10pm
excossack
Cheers Chaps.
I am not doing the job, a garage is. Looks like I will remove the cubby box and then mud stuff tunnel as well as the carpet in preperation for the work to be done.
The garage has a 4 poster. The gearbox will have to be split from the box as the gearbox has gone and at the same time the clutch is being swapped out as well. 1999 Defender TD5 110
Regards
John M0VAZ
Post #373203 21st Nov 2014 8:10am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
When I do them all I do is unscrew the tansfer knob lift the gaitor up the remove the main gear lever, then everything else from under neath or under the bonnet, but I have a 4 post ramp and a cradle that fits the gearbox and transfer box in one it does make life easier!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #373214 21st Nov 2014 9:01am
amondeggs
I wished I had a four post ramp Laughing
Post #373217 21st Nov 2014 9:09am
excossack
I wish I had one as well....and a garage 1999 Defender TD5 110
Regards
John M0VAZ
Post #373234 21st Nov 2014 11:13am
