Home > Td5 > Gearbox removal |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17312 |
Assuming the Td5 is similar to the TDCi, the box must come out downwards. You'll need to remove the panel on the seat box between the front seats, and the centre tunnel of the floor. The crossmember under the box has to come off of course.
You can drop the unit easily on a transmission jack but it is often easier to remove the transfer box first, then the main box (definitely worth it on the Puma since it allows the notorious splined shaft to be inspected). |
20th Nov 2014 10:36pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5642 |
If you have ramp and g box jack, it can all be done from underneath and in one unit. But is easier if you get access from above and splitting the boxes makes it much lighter. If you are just doing clutch, then leave boxes together and just move them back out the way.
20th Nov 2014 11:05pm |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 |
Don't forget to remove the starter motor also, this is one of the most awkward parts as one nut is difficult to get to!
Have had gear box out twice ( along story) and did it with engine crane on my driveway. This method does require the removal of the floor though Click image to enlarge Click image to enlarge Click image to enlarge Good luck with the job |
20th Nov 2014 11:10pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5840 |
Cheers Chaps.
I am not doing the job, a garage is. Looks like I will remove the cubby box and then mud stuff tunnel as well as the carpet in preperation for the work to be done. The garage has a 4 poster. The gearbox will have to be split from the box as the gearbox has gone and at the same time the clutch is being swapped out as well. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
21st Nov 2014 8:10am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 556 |
When I do them all I do is unscrew the tansfer knob lift the gaitor up the remove the main gear lever, then everything else from under neath or under the bonnet, but I have a 4 post ramp and a cradle that fits the gearbox and transfer box in one it does make life easier!
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
21st Nov 2014 9:01am |
I wished I had a four post ramp
21st Nov 2014 9:09am |
I wish I had one as well....and a garage 1999 Defender TD5 110
21st Nov 2014 11:13am |
