Home > Puma (Tdci) > Antifreeze Concentration
CapeLandy
South Africa
I have been mulling over something that has been worrying me since my radiator was replaced.
When I went to collect the vehicle the first thing I did was open the cap on the bottle and found the tank totally empty. No surprise - usual Land Rover lack of proper checks. Confused
They call the mechanic who comes running with a water canister and starts filling the bottle.
I ask him why he didn't use the bottle of antifreeze and he says "no it's fine because I already used four bottles so I can now just add water"
Two things worry me now after checking the manual 1. They mention 50% mix - at 10 litres which means 5
bottles and that would be at full concentration. Would the whole system have been drained to change the radiator?
2. Is the LandRover product pre-mix or concentrate?
Can I get something simple that will be able to tell what LR have in my cooling system as far as concentration is concerned?
Apretiate some advice.
Post #32382 17th May 2010 1:07pm
dgardel
Italy
Re: Antifreeze Concentration
Prepare 1 L each time of 50% mix and add up to your circuit will be full
Land Rover "ready to fill" (50% mixed) code
1L STC50529
5L STC50530
20L 8510373 (yes w/o STC)
25L STC50524 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32386 17th May 2010 1:35pm
dgardel
Italy
And remember to use demineralized water (ask to you wife the iron steel water.... Mr. Green ) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32387 17th May 2010 1:37pm
CapeLandy
South Africa
Thanks D
Sounds like they tried saving costs and only put 4 bottles readymix as opposed to 10 bottles Shocked
Probably best I drain the system and add some Castrol Branded pre-mix rather.
I cannot seem to find the bleed screw anywhere as mentioned in the manual.
Anyone know if we have one or is it a leftover clause from a TD5?
Post #32389 17th May 2010 2:21pm
MK
I think you have to drain from the fuel cooler ( Shocked ?)
The stuff has to meet the Ford WSS-M97B44-D spec. Puma 110" SW
Post #32395 17th May 2010 4:41pm
CapeLandy
South Africa
Read the rear lable on the bottle and it seems it is concentrated rather than pre-mix so it may be a little week if he only filled 4 bottles but probably not a train smash Embarassed
Post #32476 18th May 2010 6:05pm
